Toshiba CT-859 Remote Control 72795473 Logo
A
Anonymous Posted on Jan 04, 2016
Where is the input/source button - Toshiba CT-859 Remote Control 72795473
Level 3:
  • Toshiba Master 6,688 Answers
  • Posted on Jan 04, 2016
Cindy  Wells
Toshiba Master
Level 3:
Answers
6688
Questions
0
Helped
3532827
Points
21745
The TV/Video button at the bottom left of the Toshiba CT-859 remote toggles between the TV and external video sources. This button is below the Reset button. The CT-859 remote works for several Toshiba TVs, including the 19A24. The manual for this TV describes the remote buttons on page 6. The manual is available online at Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/19A24-Toshiba-COLOR+TELEVISION-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0407309.pdf .
I hope this helps.
How do I change the input without A remote
If you don't have a remote for your TV, you can still change the input using the buttons on the TV itself. Here are the general steps:
  1. Look for the "Input" or "Source" button on your TV. It may be labeled differently depending on the brand and model.
  2. Press the "Input" or "Source" button on your TV repeatedly until you reach the input source you want to use. Each time you press the button, the TV should cycle through the available input sources.
  3. Wait a few seconds after pressing the button to allow the TV to switch to the selected input.
If you're not sure which button to press or if this method doesn't work, refer to the user manual for your TV or contact the manufacturer for assistance.
Can't change the menu from the clock set up to other functions such as channel scanning.
Are all of the sub-menus besides the clock unavailable or just the ones related to OTA (RF) signals? If it's just the OTA menus that are missing, change the source/input to TV. On all of my TVs, the channel scan option and related functions are blocked if the current input is not TV.
Changing the input/source depends on the TV. First make sure that an antenna or cable source on an RF (RG-59/RG-60 cable) is connected to the set. Next look for a Source or Input button on the original remote. Press this button. On some models, you navigate through the menu by pressing the Input/Source button repeatedly and then press OK to change the input. On other sets, you navigate with the arrow keys and then press OK. Some TVs may switch to the new source after a few seconds without any button presses; they don't need the OK button to be pressed. On a universal remote, you may find an Input/Source button but the button may not work with some codes for the manufacturer. (This can be frustrating since the basic functions (power, channel up/down, volume up/down) work; try a different code.)
Some TVs will also have an Input/Source button on the TV. This will work like the button on the remote. Use the Select button for the OK button. A few TVs have the option inside the on-screen menu. Press Menu and then look for a source option in a Tools or Setup menu.
I hope this helps. I have never had a TV where only the Clock menu is available. If that is the case with your TV, I don't know of a solution.
Vizio TV Input Menu Scrolling
Have you got any other remotes in the room that could be faulty or interfering with the WDTV.
Also:
try resetting via the side button with the unit on.
resetting to factory defaults via the internet menu.
unplugging the unit from power for some minutes (not seconds).
Do all the above one after the other before using the WDTV.
Sometimes this helps particularity after a firmware update.
The input source of the TV can be changed either through the supplied TV remote or physical buttons located on the TV itself.
Changing input source using the supplied TV remote.
  1. Press the INPUT button on the supplied TV remote.
  2. The input source screen will be displayed on the screen of the TV.
  3. Using the arrow keys, choose one of the input sources on the input selection screen.
  4. Confirm the selection by pressing the Enter button.
Changing input source using the physical buttons on the TV.
  1. Press the INPUT button located at the back of the TV panel.
  2. The input source selection screen will be displayed.
  3. To scroll through the options, press the INPUT button repeatedly. The last highlighted option will be chosen after few seconds.
2answers
How do I access input source on my seiki tv without remote
Without knowing the exact model it would be hard to know the format. In your case I've looked at one manual and where the power button is there is also one button for volume, one for channel and one for menu and source together (4 buttons total). Each button rocks up and down, so the menu button should be up and on that same button source (input source) should be down. Once inside source navigate with Channel button.
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
JUST GOT THIS HOOKED UP THIS MORNING,NICE TV.ANYWAY NEED TO HOOK UP MY DVD PLAYER NO VIDEO BUTTON TO CHANCE FROM TV TO DVD WHATS UP? MOVIES WILL NOT PLAY
input source button and what input did you stick the DVD player into was it HDMI1 port cause if it was you would change input source to HDMI1 from DTV input source.
on the tv you have the remote control it has a source button just left of the channel up and down + ch - buttons.
When pressing menu on remote control I do not have a tv section listed to tune in channels
The TV channel settings Menu is usually only available when the Input is on TV. Look for a Source or Input button on the TV or the remote. Press this button and try to change to the TV source option.
Please add a comment with the make and model of the TV for additional information. (Unfortunately, many TVs don't let you change the source after pressing the Menu button and they don't always have a Source/Input button on the TV. Additionally, some replacement remotes don't even include a Source or Input button. For those with an Input button, you may need to try other codes to see if any will correctly work with the TV.)
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
