Garden Logo
r
roy mercer Posted on Jan 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set idle on my homelite super2 chainsaw
Claude Kayser
Level 3:
Top Expert:
  • Homelite Master 9,098 Answers
  • Posted on Jan 03, 2016
Claude Kayser
Homelite Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066805
Points
28436
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Good morning,I have a homelite super2 chainsaw,the pull string doesn't roll back after pulling it to start... what can be wrong and how do i repair it. thank you.
recoil spring or internal movement worn
ask you chain saw repairer/ part supplier
you might be able to get a used off the shelf bolt on replacement or have to pull yours apart
by the pictures
not an easy pull apart repair
new coil spring can let go while refitting it
recoil rope holder is plastic and set into the side casing
looks like you have to undo that side casing of the saw including the rolled hold handle
index-00nkgcv3qozdkgxfkoitxhz4-2-0_0.jpg44-00nkgcv3qozdkgxfkoitxhz4-2-2.jpg33-00nkgcv3qozdkgxfkoitxhz4-2-3.jpg
2answers
I my homelite chainsaw was idel screw will not stay were I set it. It keeps making the chainsaw run too high. How can I get the idel screw to stay were I set it?
There should be a coiled spring on the idle screw. Since an idle screw is most often never tightened all the way down, the spring helps to keep it in the desired position by creating tension on the screw.
1helpful
I need to know fule oil ratio for homelite super2 chainsaw
Generally small tool 2 stroke engines run on a ratio of 50:1
That's 100ml of oil in 5L of petrol
Homelite chainsaw model 4620c will not idle unless it is in the half choke position
If the jet screws have slot heads, set 'L' CCW about 1/2 turn more or less. If proper, the engine should idle fairly well, yet allow the engine to 'follow the throttle'. If the jet screws have 'D' heads, you will need to either make a 'D' head screwdriver, or take the saw to a service dealer for adjustment. If the chain is trying to turn after the above adjustment, set the idle speed screw CCW until the chain stops trying to turn. Hope this helps!
4helpful
2answers
How do i adjust the carb a homelite super2 chainsaw when i give it gas it quits but will idle
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay/damage. Make sure that all of the carburetor fasteners are tight including those that hold the carburetor to the cylinder. Go to: http://www.drystacked.com for a helpful 12 page article on Walbro carburetor theory and troubleshooting. Pay particular attention to the location of the lower chamber gasket/diaphragm components. The two jet screws are likely to be 'D' headed which means that you need a special screwdriver to adjust them and servicing dealers are supposed to the only ones allowed to perform this adjustment (thanks to the EPA in the USA). Hope this helps!
2helpful
Hello, I have came upon a Homelite Super2 chainsaw i can get it to start for a seconds then sputters out. Would like to take it apart and clean it up, any help is appreciated and thank you. need a manual.
Check the fuel filter for plugging, the fuel lines for hardness/cracks/splitting, and the air filter for plugging. Check the muffler for plugging as well. If still reluctant, dismantle the carburetor, clean, and re-kit. The lower diaphragm is prone to harden and crack. Good luck!
Idle speed for hoelite classic 200 ut 10791c chainsaw?
Idle speed is not usually set to some specific value, but is set to stop chain movement at idle, but allow the engine to keep running. Hope this helps!
5helpful
2answers
Where is the air filter on a homelite super2?
If you remove the top plastic cover on top of the saw, you will find the air filter under that cover.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
