I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
hello, it sounds like to me that your clutch is going out on u and mos tlikely did . this means u may or will have to replace the motor or just pick up a used one or new one .
hope that helps.
good luck.
thanks.
veronica gillespie
If your washer spins but does not pump the water out,
the drain line is probably clogged. In many washers a small sock or
other piece of clothing can get between the clothes tub and the outer
tub that holds the water. If the clothing gets between the tubs, it may
then get into the drain hose that is attached to the pump or even into
the pump itself. It it's in the pump, you need to remove the hoses from
the pump and pull the item out.
To remove the item from the outer tub port, open the
washer's main access panel and remove the large diameter rubber hose
that connects the pump to the bottom of the outer tub. Using a
needle-nose pliers, try to grab and remove the stuck item through the
port.
Check your washer for a frozen pulley. Remove the pump
from the washer and try to rotate the pulley manually. If it doesn't
turn freely, it's frozen, replace it.
If the water that pumps out of the machine goes back
after the spin cycle, your washer is siphoning the water from a laundry
tub that has a slow drain back into the washer. The usual remedy for
this is to improve the draining of the laundry tub.
Also check for these problems:
If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hello srcoray, Did you replace the clutch, just trying to get a feel for your hands on experience with the machine?If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing? The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle. In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW.Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW.I’m an owner like you and will try to help.
Just a few other questions; If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors? With the lid raised can you rotate the wash basket CW?It should not; it should only rotate CCW and do that with very little resistance.
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
this is correct, the machine will only fill the clithes to a saturation point and not much more part that at all, as the cycle progresses and more water is needed it will addd accordingly, yo have an extremely efficient machine there!!!1/3 the water and 1/2 the electric of conventional top loading washers
check your knob and sleve on the timer to see if they are the right
ones or if they line up. if they doit might be the pin in side the
timer.or it might be faulty. another suggestiion is check everything
out twice. good luck
