I have a samsung tv, model #LN32B360C5D that stopped working. In the upper left hand corner of the TV the letters PC (in orange) can be seen. What should I do?
Ldvs board if your lucky if not most likely damaged Lcd panels board connection to screen . Try pressing upper left upper center and upper right of screen while tv is on see if screen clears up while your pressing .
Contact the authorized service centre. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
There's a tiny orange light near the upper left corner of the touchpad to the left of the touchpad. If that is lit, you may only have to tap the upper left hand corner of the touchpad a couple of times to get it to go out. and start the touchpad working.
Barring that, see if the synaptics driver is installed. Go to "Control Panel," change the "view" in the upper right hand corner to "large icons," and see if "Synaptics Touchpad V8.1" is listed.
If not, go to "Control Panel," locate device manager and click (with a usb mouse) "mice and other pointing devices," click "Synaptics PS/2 Port Touchpad," and check to see if it says, "device is working properly." If not or if it still doesn't work, click the driver tab, and click "update driver."
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
You may find it in your "Menu" button on your remote, search for anything similar to "HD Logo" and turn it off. Failing that, make sure it isn't stuck on with transparent plastic, haha.
