Question about Pride Value Line Revo Scooter 3 Wheel
Do all new Revo scooters come with newer low
Do all new Revo scooters come with the newer low profile tires? If so can these tires be changed to the old style foam filled tires?
  • loisaz Jul 24, 2009
    WHY? CAN THE ENTIRE WHEEL ASSEMBLY BE CHANGED? THE OBJECT BEING STABILITY OF FRONT END.
  • 130 Answers
SORRY,BUT THEY CAN'T BE CHANGED BUT ON UP SIDE THESE R SMOOTHER
Posted on Jul 15, 2009
SOURCE:
Does anyone know the bead width for the front tire hub on a s131 merits scooter. I want to replace the tire with a foam filled. Thanks.
The pioneer 3 S131 tire size is :
3.00 - 4 or
260 x 85 or
10" x 3"
The front foam filled tire is available from New Solutions 800-429-9600.
It is probably the ribbed rounded style tire # F057. This profile makes it easier to steer. I am attaching the catalog pictures to match the numbers on your existing tire to their product line. I would also recommend replacing both rear pneumatic tires with foam filled. Hope this helps.
Aug 21, 2016 | Health & Beauty
What are the POST codes for a revo power scooter
Go to my app and look up Flash codes for Pride Revo. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jun 15, 2014 | Electric Mobility Mobility Electric Power...
The rear axle on my fortress 2000 scooter moves about 1/4 inch to the left or right causing the left and right wheels to rub on a bolt on the inside of the tires. Is there a way to tighten the axle to...
there is a bearing inside pin roller this get no grease unless pulled apart and serviced so if this has not been done the bearing is most likely worn out take apart and find bearing number very small ### so wash in solvent to see it go to auto parts store and order new 1
Oct 21, 2013 | Pride Revo 4 Wheel Scooter
My Pride Revo Mobility scooter needs a new gear box.
never said how old it is,cant give you a good answer without knowing.
Sep 13, 2012 | Pride Mobility Revo 3 Wheel Scooter
Low tire pressure indicator came on today. All tire are at right pressure. How to reset?
BMW low tire pressure sensors use the speed sensors at the wheels to detect a flat tire. If any one tire is much newer or older than the other three, the warning will trigger. Tire chains tend to set it off as well.
There should be a button on the console that has a pattern that looks like the low pressure warning light - the profile of a tire with an explanation point inside. After you start the engine but before moving, press and hold that button until the warning light in the instrument cluster illuminates yellow. Then drive normally. That should re-initialize the tire pressure warning system.
Jan 25, 2011 | BMW 325 Cars & Trucks
The motor on our brand new Revo 3 Wheel makes a ticking noise about every revolution of the wheels. This is our second Revo, the company exchanged the first one due to the same problem that they could not...
Trent I had this with another scooter and it turned out to be a cut or piece missing from one of the tires. Check all the tires carefully for any little defect or gouge. If you find something fishy take a piece of tape and cove the defect and the drive the scooter and see if you still hear the ticking sound. If that doesn't help block the rear of the scooter off the floor and have your wife run it slowly carefully listen to both rear tires to see if you can find the one making noise. If you can't hear the noise block up the front tires spin them to listen for the sound you are hearing. Hope this helps and let me know what you find Good Luck
Oct 01, 2010 | Pride Mobility Revo 3 Wheel Electric...
The scooter is not taking the charge,the light stays yellow & red.
hi, first check the charger, can you try another charger ?
if you're convince the charger is charging ok then it points to the batteries being tired and need replacing but first check the connections to make sure there is not a loose connection.
Regards
GeWiz,
Jan 01, 2010 | Pride Mobility Revo 3 Wheel Electric...
Need Wiring chart for Revo 4 Pride Mobility Scooter
I have wiring chartfor Revo if your interested
Nov 08, 2009 | Pride Revo 4 Wheel Scooter
Having trouble with finding the right tire pressure for my 2001 Toyota MR2 Spyder; I just cant seem to get the right pressure . Its too stiff if too full and anything other thsn too full it just grabs...
If you are running on newer low profile rims and tires,,then the only option is to change to a softer shock absorber.
Since the newer low profile tires need to be at full pressure or your handling is going to be dangerous
Jan 16, 2009 | Toyota MR2 Cars & Trucks
Pride Value Line Revo Scooter 3 Wheel Logo
118 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
