Hello Tracy, thank you for your post!
From what you have described you need help putting your Frigidaire washer into a clean cycle. In order to further assist you I would need your model number. You can locate your serial tag (which lists your model number) on the door frame of your washer. With that information I would be happy to further assist you. -Matt
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
SOURCE: My washer stops half way through the cycle and
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
SOURCE: how to clean a affinity frigidaire front load
remove the toe kick panel just below the front door and its located right below the drum
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Hey friend, thanks for your post!
Based off the information you have provided it sounds like there could be a buildup of soap within your appliance. I would recommend performing a clean cycle on your appliance which can be done by using a hot wash cycle and a cup of bleach. I hope that helps to some degree. -Matt
