Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
r
rita markley Posted on Jan 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the power level? - Samsung 1.8 Cu. Ft. Over-the-Range Microwave
tuffbird72
Level 2:
Habit-Forming:
New Friend:
  • Expert 44 Answers
  • Posted on Jan 03, 2016
tuffbird72
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
44
Questions
0
Helped
13467
Points
182
This is from Page 16 in the users manual...
For simple, one-stage cooking, you only need to set the cooking time. The power level is automatically set to High.
If you want to set the power level to any other level, use the Power Level button.
1. Use the number buttons to set a cooking time. You can enter a time from one second to 99 minutes and 99 seconds. To select a time greater than one minute, enter the seconds too. (For example, to set a cooking time of 20 minutes, enter 2, 0, 0, 0.)
2. If you want to set the power level to a level other than High, press the Power Level button, and then use the number buttons to enter the power level.
3. Press the ENTER/START button to begin cooking. If you want to change the power level, press the STOP/ CLEAR button before you press the ENTER/START button, and then enter all the instructions again.
Samsung Microwave power level - no button
As you didn't specify any specific model, one of the Samsung models uses this scheme to change power levels.
You begin by pressing the "Microwave" button once. Pressing it again will display different power levels, from low to high.
How do I set the power at 50%?
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
1helpful
Hamilton beach microwave change power level hp-p100n30al-s3 how do I do that? I pushed the power level button and only beeps does nothing to it
Hit power level button then number 1 through 10. Most have 10 power levels. 1 is extremely low. 3 is usually defrost, 5 would be half power and so on.
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
2helpful
How do you change the power level?
On most brands, you enter the cook time, then press the "Power Level" key, followed by the using a single digit key for the desired power percentage, then hitting "Start".
EXAMPLE: Too cook for one minute at 30% power:
Time Cook > 1 > 0 > 0 > Power Level > 3 > Start
A possible alternative key combination may be:
Time Cook > 1 > 0 > 0 > Power Level > Power Level >Power Level > Start
Here is a guide to power levels:
1helpful
How do change the power level?
My GE Microwave Oven won't let me change the Power Level. It is on 10 and takes forever to warm up food. It is supposed to default to Hi but doesn't. I followed the directions for changing the...
There is a solid state switching device called a triac "electronic voltage controller" that has malfunctioned, it controls the power level settings when making power selection, It will need to be replaced to correct the problem. This repair should be done by a qualified technician because dangerous high voltages are present.
3helpful
How can I change the power level on my GE Spacemaker microwave? When Power Level button pressed, I keep getting the message: "Power level may not be changed at this time".
You can download your owner's manual here.
1helpful
Microwave oven
maybe it is running. you can not change power while the unit is running. you can only set the power level while programming the heating schedule.
33helpful
3answers
Changing the power level
I had the same problem. All you need to do is put in your cook time first, then adjust the power level. So time cook, whatever # of minutes, power level, then # power level. Hope this helps.
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
