SOURCE: vtech 9127, display bad
my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time 4x I could hear the other person~they could not hear me and then disconnect.
Characters and numbers are choppy too
Thank you
SOURCE: vtech cordless phone/ detc 6.0
This worked for me. Unplug the power to the base for 10 seconds then plug the power back in. That did it for my "connecting....." problem. Good luck!
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: hi, how do you turn the ringer on of vtech 5.8 GHZ
http://www.retrevo.com/d/ds/progress?doc=415c14b0b538f65e013116610ddd5a8a
Click on the above for your manual and go to p7.
Hope it helps!
