1992 Saturn SL Logo
p
paul eggleston Posted on Jan 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my heat or air is not blowing and car is running hot
Car over heats and no heat or air blows out
Bill Wheeler
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 02, 2016
Bill Wheeler
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
3957
Points
20
I am not a motor mechanic but i would follow this route:
If the heater IS only blowing cold air -
1. check that you have water in the radiator.
2. If you have water it could be the water thermostat stuck closed.
3. If not the thermostat it could be the water pump.
If the heater is NOT blowing any air
1. Check the Fan Fuse
2. Suspect the fan blower motor
jack layton
Level 3:
  • Saturn Master 5,569 Answers
jack layton
Saturn Master
Level 3:
Answers
5569
Questions
0
Helped
2397670
Points
20059
How hot is the engine running in degrees f? Does the radiator fan run?
With hvac turned on, check voltage and ground at the blower motor. If good voltage and ground, suspect the blower motor is faulty.
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
2answers
My 2004 Pontiac Aztek isn't blowing heat. It blows cold air. I had a coolant flush in december.
You probably have an air bubble and therefore doesn't have enough anti freeze in the system. Carefully remove the radiator cap when the engine is running and verify it and/or notice the hot/cold marking on the overflow tank. The system needs to be full to heat.
Problem with heating up and staying heated.
Thermostat is sticking or heater core is blocked.do not keep running it or it is going to ruin the engine. It is running hot regardless if is blowing cool or hot air. Do not keep using the car.
Ac blows out hot air in hot climate and cold air blows out the heat when i turn it on
bmw 5 series on 2005 2.5 diesel when i put the heats on hot air it blows cold air.
Heater blows won't get hot
Hi.
Technically, that's impossible. The heating system in your car gets its heat from the engine. If the engine is running, then it will generate heat and there's no stopping that. The only thing that would prevent the heat from getting into the air that's blowing into the car is if the air selector is set to "Recycle" instead of "Fresh".
So, look at the controls for the heater and be sure that the air selector is pulling air from the outside and into the car.
I hope this helps.
Randy
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Overheating
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
1helpful
2answers
Why would my heater blow out cool air when sitting still and then hot air when going down the road and then it's not all that hot
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level. only put in straight antifreeze, do not mix. most people do not know what mixture should be, so be safe and add straight, it will not hurt it, i run 100% straight antifreeze and never had a problem or worry about it ever freezing and cracking my block, heads or radiator cracking.
1helpful
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Heater not working
What does that mean? It blows air but not hot air? It doesn't blow air at all with A/C or heat? I assume you mean it blows, just not hot. If so, make sure your car is running at operating temp. If the car isn't warming up, your thermostat is stuck open and the coolant can't heat up enough to transfer heat from the heater core to the air you're blowing out the vents. If your car warms up to operating temp just fine, you may have a heater core issue. Your core may be clogged with corrosion thus not allowing heat transfer as well. If the valve on the inlet hose to your heater core is bad it won't allow hot coolant into the heater core, once again no heat to the air blowing out your vents. One of these is most likely your issue. I hope this helps.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
