If the arm does not clamp over the bobbin case, it is probably because the bobbin case is not securely in its place (make sure you are using the correct bobbin and it is loaded into the bobbin case correctly). Be sure that the bobbin case is inserted correctly and securely latched.
If problems continue, may want to consult a repair service.
