How to set up U8 SmartWatch + Install BTNotifications Easy ...
? 3:39
https://www.youtube.com/watch?v=Y2E-vQy5BM0
Oct 31, 2014 - Uploaded by VitalKid Reviews
Tutorial on how to get your U8 Smart watch up and running. All Links in Description. ... +VitalKid Reviews HOW ...
SOURCE: How do I set date & time?
usually breitlings have a screw-in crown with a gasket for diving. If you cannot pull the crown away from the case, try unscrewing it. After a little pressure to the left, the crown should begin to turn. Unscrew it carefully and you should be able to pull it out one stop for the date and all the way (note second hand stops) to set the time. Be careful pushing it back in and screwing it back down. You don't want to potentially damage the threads. The crown is back in place when you ca't screw it in any more and the "B" is straight up and down
SOURCE: how to set time and date on digital watch have lost the manual
de button on the side of the watch got 3 stands:
- totally to the left is nothing
- totally to the right is set time/hours/days
- in the middle set date.
Hope this helps
SOURCE: how do I set time and date on my automatic Steinhausen watch?
you can refer to the customer service on the Steinhausen
homepage:
http://www.steinhausenonline.com or call free: 24/7(800)208-2607. they can offer you the best advice.
SOURCE: Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
