I was able to connect the printer with USB cable to the Acer Chromebook but it said I need an software update to enable the printing.
SOURCE: HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
SOURCE: HP PSC 1410 All-In-One printer speed is slow
Hello Sir,
I would like to provide you few workaround steps, you may try to improve the printing speed on the computer.
Delete all the Temporary files:
For Windows XP:
(1) Click Start >> In the Run window, type "%temp%" which opens temporary files folder.
(2) Delete all the files that are listed over there.
If Windows Vista:
(1) Click Start >> Programs >> Accessories >> In the Run window, type "%temp%" and press enter.
(2) Delete all the files listed under temporary files folder.
Another Workaround:
(1) Click Start >> Printer and Faxes.
(2) Right click on the Printer icon which is set as default and select properties.
(3) Click on Advance Tab.
(4) put a check mark on "Print Directly to printer" option.
(5) Click Apply and Ok.
Hope this solution would be helpful in resolving the issue that you are experiencing.
With Regards,
Ashesburn..
SOURCE: HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
please let me know what is rail and carriage bushings ?
This eror usually mean that the printer cartridge has not been installed correctly. Try re-installing the cartridge. This error can also be generated by a logic fault within the printer.. if this is the case, replace the printer.. trying another new cartridge can be expensive so try and get a second hand cartridge, maybe from a friend and try that one.. Otherwise, replace the printer..
SOURCE: HP PSC 1410 All in one printer
Reset the HP All-in-OneFollow the steps below to reset the All-in-One.
