Question about Riccar Generic 1400 1500 1700 1800 Pristine Charisma And Sunbright
Quit running. board has power. led is flashing on board, 1 per second.thermal limit has continuity. fuse is good.
When i press the wreck magnesium power button the unit starts but turns off after ten seconds. What the problem as the light continues to flash.
Robert,
You could have a couple of problems. 1, you could have a broken belt, 2, you could have a bad sensor, or 3, you could have a bad pc board. The Magnesium has a sensor that detects whether or not the brush is turning. A quick way to check would be turn the vacuum over and turn it on, if the brush does not turn in those 10 seconds, you have a broken belt. If it does turn, I would suggest taking it to an Oreck repair store because it may still be under warranty and the sensor or pc board may still be covered under warranty. Hope this helps!
Mar 02, 2015 | Oreck Magnesium Upright Vacuum
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Motor quits
Does it come back on right away or do you have to wait a while. It could be faulty thermal sensor because it should not overheat in 30 seconds. Probably will need to replace motor if so.
Nov 03, 2013 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Shark navigator will not turn on
Plugged in:
Try moving the cord around at the strain relief, where cord enters the vac, as internal wires may have broken.
Unplugged:
Check brushes of electric motor, they may be worn down.
Unplugged:
Check main switch continuity with a meter on ohms or buzzer.
Limits:
No.
But there could be a thermal fuse either in or on the motor, to avoid overheating damage and smoke signals!
Nov 20, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
I have a euro model s3325 and when i turn on the power switch it says its steam ready but will not heat up
I think it may be from the same issue stated above--the thermal fuse blew. I have the exact same problem. This is what someone posted earlier:
There's a thermal fuse inside. If it gets too hot, the fuse will blow and the thing won't turn on.
It has a 216 C temp limit. You can find thermal fuses at radio shack for less than 5$. If you're adventurous enough, you can find the fuse in line of a white wire under a fiberglass outer and heat shrink inner shielding screwed against the bottom of the tank.
Now to figure out how to get to it!!!
Aug 12, 2011 | Euro-Pro S3325 Handheld Steam Vacuum
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
Shark Euro-Pro cordless vacuum won't start
Sounds like it needs to be serviced. Call customer service here to help you.
Tel: 1 866 98SHARK (1 866 987-4275)
Is it still under the 1 year warranty.
Good Luck and Please Rate FixYa!
Mar 12, 2009 | Vacuums
Possible reset on Thermal Cut-Off
This is not really expert advise but I have a vaccuum with hepa filters and if the filters get dirty My vaccuum acts like your what you are describing.
Jan 07, 2009 | Eureka Vacuums
Riccar Generic 1400 1500 1700 1800 Pristine Charisma And Sunbright Logo
83 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
