SOURCE: power chair lights
The problem was a bad joystick. A local company came out to replace it and it works fine now.
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
SOURCE: wheelchair will not run. lights blink on and off
may have damaged one of the two motors or disconnected motor plug.
SOURCE: Right out of the box, my ML-2510 has a solid red error light
You should install the software prior to connecting the printer, to make sure the provided drivers are ibstalled and not the generic ones that come with Windows.
