Why does the soundbar play with Roku but no sound comes from the bar when on regular t.v.
Soundbar is an Insignia with wireless woofer ( NS-SB515 )
Have tried everything the book suggests to do, even called support tech and they couldn't assist.
Re: why does the soundbar play with Roku but no sound...
You have to go into the audio set up screen on the TV and direct TV sound to the output cable connector you used for the sound bar. Example: Optical, digital.
Here are some troubleshooting steps you can try to pair your woofer with your Vizio VHT215 soundbar:
Power cycle: Turn off both the soundbar and the woofer and unplug them from their power source. Wait for a few minutes before plugging them back in and turning them on again.
Reset the soundbar: Press and hold the Bluetooth button on the soundbar until you see the light on the front panel start to flash rapidly. This will reset the soundbar and put it into pairing mode.
Reset the woofer: Press and hold the Pair button on the back of the woofer until you see the light on the front panel start to flash rapidly. This will reset the woofer and put it into pairing mode.
Check the distance: Make sure the woofer is within the recommended distance from the soundbar. Typically, this is around 30 feet or less.
Check for interference: Other wireless devices or electronic equipment in the vicinity can interfere with the Bluetooth signal. Move any such devices away from the soundbar and woofer, or turn them off temporarily.
Replace batteries: If your woofer uses batteries, make sure they are fresh and installed correctly.
If none of the above steps work, you may need to contact Vizio customer support for further assistance.
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
