A
Anonymous Posted on Dec 30, 2015
Why isn't folder button working? - Olympus Audio Players & Recorders
Where is the menu button?
You mean the start button? There isn't one. Instead, the dock at the bottom of the screen is used to launch applications. If the application that you want is not shown on the dock, click on the folder icon with an "A" on it, which is located on the right hand side of the dock, this opens a representation of the Applications folder, which includes all applications installed on the computer. You should be able to find the application you want in there, or if not, perhaps you need to obtain it and install it first.
Yahoo mail isn't working properly. I can't delete any of my messages, even my spam folder. It won't even allow me to click on the help or options link. I had to go through the search bar to...
Good Day Kimba!
If Yahoo Mail is not working properly, the problem is with your internet browser. It is a sign that you have a weak internet browser.
Uninstall your internet browser , then, download a new version and install.
If you are using Internet Explorer, upgrade to a newer version.
If you are using Mozilla Firefox or Google Chrome, uninstall it and download the latest version.
After that, try to sign in on your Yahoo mail account and you will find all function buttons are working fine.
Let me know if I can help you further.
Thanks for asking Fixya.
Aug 11, 2011 • Yahoo Mail
1helpful
I HAVE AN ECLIPSE 180 AND IT SAYS IT'S COMPATABLE WITH ITUNES BUT IT SYNCS AND SAYS ITS DOWN LOADED BUT WON'T PUT IT IN THE LOCAL FOLDER IT IS IN THE EXCHANGE DATA FOLDER AND I CANT PLAY THE SONGS....
The Mach Speed Eclipse 180 isn't compatible with ITunes despite what you heard. However all hope isn't lost.
If you are using Microsoft windows simply use the sync feature in Windows Media Player.
If you are using a mac, the player displays as a removable device, simply drag the music into the mp3 or music folder.
Now Eject your device and have fun!
If in Doubt Check the link below
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/55041503_PM_EN.pdf
2helpful
I have lifeframe 3 on my laptop asus k53b I can take pictures and the cam works fine but it wont save or move any pictures into a folder on my pc, I used the Save as button but that only makes another...
Hi Welcome to Fix Ya. I also use an Asus with Lifeframe. Have you tried copying the photos to your Photo folder in your default picture library?
In other words, if you right click your photo in the lifeframe app and select "copy to" a drop down menu will appear that reads: "Select Folder."
2. Click on your Win Profile name. Then select "My Pictures" folder. The path will read: C:\Users\Your profile name\Pictures
3. You can then make a new folder or you can save it in the Lifeframe folder in a new separate folder.
Hope this helps. Thanks for using fix ya!
I cannot preview my pictures in my memory card, and it was said a 'file error'
First, try to copy this files at pc folder, then try to open there. If this isn't work, its possible that your files are dirty or your SD card is damaged.
May 26, 2011 • Cameras
2answers
Acer Travel mate 2310 USB problem can't connect new Canon printer
check the status of the USB under Device manager.If it says an Unknown Device the drivers are not gettign recognised.Try install in Safe mode with Admin rights.
Cannot delet the themes stored in the memory card pleaze help
firstly Check if d theme isn`t used by u............. if it isn`t deletn yet must b due to sum virus attachd to its folder.... connect yr phone to your pc, access yr themes folder dere and delete it den....
If it aint deletn still, scan yr mobile thru an antivirus 4m yr pc(nt 4m yr mobile)... d a.v. will surly find sum void .exe files and will fix dem..... den delete all d .exe files n yr themes.....
CAN NOT DRAG THE DOC SCANNED TO THE FOLDER
Normally only the left mouse button works for dragging PDF file from one ScanSnap Organizer folder to another.
If the left mouse button will not drag the files to another folder, try the right mouse button. If the right mouse button is the only one that works, you have your left and right mouse buttons reversed (see the Mouse settings under the Windows Control Panal).
Eric
Help dont want to lose everything
The reason it is asking you if you want to delete all is because you have not selected specific files to erase, so when you hit erase without selecting a file it assumes you mean delete all.
To erase try these steps...
To erase a selected file from Folder A, B, or C:
  1. Press the MENU/FOLDER button to select Folder A, B, or C.
  2. Press the - or + button to select the file to be erased.
  3. Press the ERASE button.
  4. Press the - or + button to select YES.
  5. Press the ENTER/INDEX button.
To erase the contents of Folder A, B, or C:
  2. Press the ERASE button twice.
  3. Press the - or + button to select YES.
  4. Press the ENTER/INDEX button.
To erase a selected file from a date subfolder in Folder S:
  1. Press the MENU/FOLDER button to select Folder S.
  2. Press the - or + button to select the date subfolder.
  3. Press the PLAY button.
  4. Press the - or + button to select the file to be erased.
  5. Press the STOP button.
  6. Press the ERASE button.Press the - or + button to select YES.
  7. Press the ENTER/INDEX button.
To erase the contents of a date subfolder in Folder S:
  2. Press the - or + button to select the date subfolder to be erased.
  3. Press the ERASE button twice.
To erase the contents of a month subfolder in Folder S:
  2. Press the ERASE button three times.
  3. Press the STOP or PLAY button to select the month subfolder to be erased.
  5. Press the - or + button to select YES.
  6. Press the ENTER/INDEX button.
To erase the contents of Folder S:
  2. Press the ERASE button four times.
I want to delete some files!
PS. here is a link to download manuals and software for this device:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1080
Good Luck ... oh and dont forget to rate my response.
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
