"P" mode in most digital cameras is, "Program", meaning that it's really kind of manual. Attempting to shoot flash in this mode is likely to be difficult. Suggest "A", or "Automatic" mode.
If you're in one of the PSAM modes then don't pop up the flash.
You can use the Auto-No-Flash mode by turning the mode dial to the position after the green Auto mode (a lighting bolt in a circle with a slash through it).
You should be able to set the flash to off, auto, auto with redeye, slow-shutter sync, and forced flash on. The last two should give you the results you're looking for. If these aren't available in manual mode, get out of manual mode.
Hi , try to flash in dark area and set camera flash on set in all option.if does not fire the flash the flash bulb are busted either the the igniter switch inside was broken.
learning to use light metering correctly can have its challenge. the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem. once you confirm that you have these settings correct and still get a dark image, its time to have it serviced. good luck mark
