Question about Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002
Why does my door open warning light come on when I touch the driverside door panel or make a right turn?
  • 26 Answers
The door switch isnt adjusted properly
Posted on Jan 07, 2016
SOURCE:
How do we get a 2006 Uplander to stop chiming?
What is it chiming ? Chimes for different reasons , headlamps on , seat belt not buckled , etc.... What warning light is lit on the instrument cluster ? if any . seat belt , air bag's etc...
Audible Warnings Description and Operation
The audible warnings alert the driver of a system concern or a critical vehicle condition. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
Fasten Safety Belt Warning
The inflatable restraint sensing and diagnostic module (SDM) activates the fasten safety belt audible warning for 5-8 seconds. The fasten safety belt warning sounds and the fasten seat belt indicator illuminates when the following occurs:
• The ignition switch is in RUN, BULB TEST, or START position.
• The SDM detects that the driver's seat belt is not buckled (signal is low).
If the seat belt is buckled before the ignition is in RUN, BULB TEST, or START position, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops.
Key-In-Ignition Warning
The instrument panel cluster (IPC) activates the key-in-ignition audible warning. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is in OFF, LOCK, or ACCY position.
• The body control module (BCM) determines that the driver's door is open (signal is low).
• The BCM determines that the key-in-ignition switch is closed (signal is low).
Lights On Warning
The instrument panel cluster (IPC) activates the lights on audible warning. The lights on warning sounds when the following occurs:
• The key is not in the ignition.
• The body control module (BCM) determines that the drivers door is open (signal is low).
• The BCM determines that the headlamp switch is in the park or head position.
Rear Parking Assist
The rear object sensor control module activates the audible warning. The audible warning sounds whenever any of the indicators are illuminated on the rear parking assist display. For a description of the rear parking assist system refer to Object Detection Description and Operation.
Turn Signal Reminder
The instrument panel cluster (IPC) sounds the turn signal reminder once per each flash of the turn signal lamps when:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit (left or right turn).
• The vehicle has traveled a distance of 1.2 km (0.75 mi) by counting pulses on the vehicle speed input circuit.
The IPC turns off the turn signal reminder when either the ignition switch is turned to the LOCK position or to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits (left turn or right turn).
Additional Chimes
The following chimes will turn on when an associated indicator turns on in the instrument panel cluster (IPC):
• Low Fuel Indicator
• Low Oil Pressure Indicator
• OVER SPEED indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation.
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console.
Your have a problem with one of these systems , your best bet , take it to a qualified repair shop. They would do diagnostic's to find the problem .
Do any indicators illuminate when the chime sounds?
Go to Symptoms - Instrument Panel, Gages and Console
Go to Step 3
Turn the ignition OFF.
Remove the key from the ignition.
Turn the headlamp switch to OFF.
Close all of the vehicle doors.
Open one or more of the vehicle doors
Does the chime sound at all times regardless if the doors are open or closed?
Go to Step 15
Go to Step 4
With a scan tool, observe the LF Door Ajar Switch parameter and the RF Door Ajar Switch parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Door Ajar Switch parameters display Door Closed?
With a scan tool, observe the Left Rear Door Ajar Sw. parameter and the Right Rear Door Sw. parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Rear Door Switch parameters display Closed?
This is a 21 step diagnostic trouble shooting flow chart .
Jul 03, 2018 | Cars & Trucks
HOW DO I DIS ENGAGE THE SECURITY FEATURE ANTI THEFT MODE 2010 AVENGER
You can't disable it. Newer Dodges have chips in the key. Older Dodges you could lock the car down and open the door with the key to disarm the alarm. Try both doors. The latch sensor in one door could be broken. If still no luck, you'll have to get it on a scanner to read codes. Code readers don't read security codes.
Jun 13, 2015 | 2010 Dodge Avenger SXT
My golf 1.6 warning door light ,,it jumps from rear to driverside to leftpassenger side etc also boot warning light comes on when i sart and driving car ..any ideas ..robbie
Most likely you have corrosion problems. Pull the plug/s at the BCM. look for a white to greenish color. Clean it as best as possible. If the BCM is at a place that has water issues(under A/C plenums). Cover it with plastic. You may need to open the BCM cover and clean the board also.
Jun 07, 2015 | Cars & Trucks
My speaker that is for my onstar, backup warning and when my key is in the ignition and the door opens alarm is not working proerly. The sound is very low even though I have turned the volume all the way...
you have many problems in one question.
Let's start with
1. BACK UP Warning is it the backup lights not working.
2. When you open the driver's door does the inside lights turn on
maybe the system doesn't know the door is open or the little switch inside the steering column is open circuit.
3. Maybe the speaker itself defects or wiring touching metal ground
many questions that I cannot answer without more infos
hope it helps
Jan 28, 2018 | 2008 GMC Sierra 1500
I have no dashlights and fuse is not in the fusebox under the hood so where is the other fuse box?
The other fuse box will be inside cabin, driverside, and either behind a panel about knee height to your left as your sitting in driver seat, or when you open your door and you can see the side of your dash that area could be a ncover for your fuse panel. That is also the drivers side. The panel may be conceled but it is there in 1 of those two places.
Nov 23, 2010 | 2001 Dodge Grand Caravan
My door locks and ligh burn where can i find it
Look as you open the door on driverside on the dash you will see a fuse panel door. open the door and look inside the lid for the location of the fuse/relay controlling the door locks and the lights. Hope this will help you.
May 15, 2010 | 2003 Dodge Neon
1999 Infinity QX4. Door Open warning light
usually on post where door closes, or in jamb by hinge area. Open door & try pushing any button/pin like object or may be a lever style too, with thumb or finger.When interior light goes out, you found it
May 03, 2009 | 1999 Infiniti.5 QX4
95 tahoe open door warning
i had the same problem but it happened because i changed the speakers and did not adjust the panel right....
try adjusting things so the panel can push back the
pin when u close the door...
check all ur fuses if you take them off nothing will happen. just put them back and your all good.
if u take one off and it shuts off the noise. make sure that all your lights on the dashboard still turn on. if they dont then ta dah....
Apr 05, 2009 | 1995 Chevrolet Tahoe
Ford Escort Alarm - Annoying Problem!
it seems that the contact circuit in the driverside door is the problem, it's obviously not the alarm itself others wise the same thing would occure on the passengerside. you have to remove the door panel on the driverside and inspect the wires in that circuit for corrosion which would cause no current to pass between the by pass switch the arms or disarms the alarm. please rate this
Oct 09, 2008 | 1996 Ford Escort 4 Door
Door Ajar Warning Light Stays On
Our Ford Expedition & an Olds Silhouette Premier & both did the same thing. Someone online said to spray the inside door where the metal connects with the frame & sensors are there with WD-40. We did & it fixed the problem. Maybe this will work for yours.
Aug 14, 2008 | 2000 Oldsmobile Silhouette
Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002 Logo
53 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
