Replaced t-con and main board
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - 25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ...
my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
SOURCE: I have colored vertical lines
Check the wire that goes from the main board to the actual LCD board. Unplug it and wiggle it around before plugging it back in. The cable is notorious for going bad. If this solves it you should be fine for a while. Eventually you may need to replace the wire. The TCON board is most likely not the culprit in this case.
SOURCE: I have a Sony KDL 52w4100 LCD tv. When I turn the TV on, all i get is a blank screen, and no sound.
Tad G chances are you installed the wrong Tconn as that model used two T con boards both look identical but they are not interchangeable the two types were part numbers 185724011 and 185713211 I can assist with determining which version you have
SOURCE: color lines on 42inch vizio
Hello
The y SUSTAIN board to your tV is faulty. It should be repalced.
