The display (timer) needs to be connected to a sensor on the bike.
Make sure the display is plugged into a cable coming out of the bike.
If it's plugged in and still doesn't work, then contact the manufacturer.
It could be,
1. a bad display. (possibly a broken PCB connection)
2. a bad sensor inside of the bike. They typically use a Reed switch.
3. a broken connection in the cable or connector
4. the magnet fell out of its location.
You can get a replacement monitor from the manufacturer. If this doesn't solve the problem then it's either the sensor or the connection.
You can also place a continuity tester across the 2 contacts of the connector that plugs into the display. The continuity tester should flash when you pedal the bike.
Here's a link where you can purchase a continuity tester.
http://www.amazon.com/Extech-ET40-HD-Continuity-Tester/dp/B0025PK724
You can also pickup a continuity tester at any auto parts store.
