Dryers Logo
Nicole Graham Posted on Dec 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone and camera cord cut. I have four colors to work with , black red yellow green. What colors are what and what ?
Paul Gustar
Level 3:
Master:
  • Master 478 Answers
  • Posted on Dec 29, 2015
Paul Gustar
Master
Level 3:
Master:
Answers
478
Questions
Helped
212791
Points
1472
Black and red are audio, yellow and green are video
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
2helpful
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
We are experiancing probems with our agua view. The light comes on on the moniter but there is no video coming through. Is there a fix for this issue
i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
1helpful
I have an aqua vu scout and it has good battery and connection but no picture
mike if you are still having this problem, i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Dec 23, 2009 • Aqua GPS
2helpful
Just got a clarion xmd1 but the wires are cut off at the plug
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
1helpful
Used maytag electric dryer installation question
First off, you should be wiring your power cord directly to the terminal block inside the dryer. If someone just cut off the cord that is terminated inside the dryer, and you are attempting to splice the new cord onto the old one.. you are making a mistake.. take the new cord and bond it directly to the terminal block inside the dryer. If you have a new 4-wire power cord, you are probably dealing with a red/black/white and green wire. ( assuming it is a four prong plug).. The black and red wires are the power lines themselves and should mate with the red and black wires inside the dryer. The green ( is frame ground) and is normally bonded to a stud near the terminal block or the dryer frame. The white is the neutral line and is normally tied to the terminal in the middle and between the red and black tie points.. In line splices should not be done on this appliance.. Hope this helps..
Sep 06, 2008 • Dryers
Aqua vu underwater camera
Top Dryers Experts
john h
