Sanyo Xacti VPC-S5 Digital Camera Logo
C
Charles Patterson Posted on Dec 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I repair a stuck main switch? - Sanyo Xacti VPC-S5 Digital Camera
Pieter Vleeshouwers
Level 3:
  • Sanyo Master 2,029 Answers
  • Posted on Feb 13, 2016
Pieter Vleeshouwers
Sanyo Master
Level 3:
Answers
2029
Questions
0
Helped
4113598
Points
7389
It is almost inconceivable if mechanical failure, but a little WD40 spray you can buy at any street corner inside spray can work wonders
My light stays on when I close the door.
If the light stayed on AND the tray kept spinning around, or a fan kept running, then I would say you have a bad door switch. But if everything else works like it is supposed to, then you probably have a relay on the main control board that is stuck closed (on) or you have a shorted triac on the main board. Since very few technicians troubleshoot down to the component level or repair boards, you are probably looking at a board replacement - a rather expensive proposition to fix a light that is stuck on.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Get wheel to turn on C300 digital camera kodak
If the main dial won't turn, you can't switch on or off and can't chose a mode.
There is no way, if something got stuck, to find out what is wrong, without opening the camera. Don't try this yourself.
Only try to turn the main dial, to the left and to the right, to see if you can get any movement in it.
I don't think it would be worth to get it repaired, because camera's are so cheap these days.
You could try to tap the camera, with the dial on the palm of your hand, but be aware a to big of a shock could damage the camera complete, Don't tap it on a hard surface.
My A42T wo't finish loading the Ifit software. which means the treadmill won't start. The software is stuck in a loop. How can I reset it or get out of this so I can use it? Thank you.
Turn it off from Machine build switch, then turn it of from mains, then unplug it from mains, wait for some time and then Plug it to mains, switch on from mains and switch on local machine switch. If the process above fails, you should contact the Dealer or Authorized Service Center.
My tv is stuck in stand by,and my remote does't switch on the tv
Television is not the main remote control from behind or the side
The machine makes some clicking noises when you try to start it and then says
Hello Al White - Typically error code ER indicates a membrane switch failure. Meaning that the main control board has detected a stuck key or key pressed for more than one minute. This will need to be checked and a repair performed by a technician since they must do the following: check connection from keypad to main control board, if correct the keypad will need replacing. If error still exists then tech will need to replace main control board.
7 years old wont switch off programme seems stuck
Disconnect power at the mains power or breaker. Leave it switched off for 60 minutes then turn it back on to see if the error has cleared or reappears. If it reappears then note any error code or flashing lights and call in a repair man.
One of our lights blew and the main trip switch is now stuck on
those stips are just on there by pressure its is easy to change them but if you never done it call some one
1helpful
2answers
My phone Samsung GT-S8003 is stuck on Download mode - GT-S8003
i have todat repair my smsung gts8003, i have relpaced main and sub pcbs, lacd and touch screen now it is howing download mode gt-s8003, what is the solution for this
2answers
Buzzing fuel pump
sounds like the fuel pump relay is stuck on. find the relay and replace it. hope this helps mike
How to mend it .com - Bosch dishwasher SGS43A12GB-27 does not stop filling
possibly the inlet water valve stuck open tho this is rare.
disconnect the valve electrically and see if the fault is still present. if so, the valve is stuck open and needs replacing
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
