Question about Panasonic VIERA TC-P55ST50 55 in. 3D Plasma HDTV
Can I use a Bluetooth adapter with this set? - Panasonic VIERA TC-P55ST50 55 in. 3D Plasma HDTV
    New Friend:
    Problem Solver:
  • 12 Answers
This VIERA model does not include Bluetooth. You CANNOT use a Bluetooth adapter with it via the TV's USB port, because the TV does not have the internal software to work with your adapter. It's a TV, not a computer!
Posted on Jul 14, 2016
SOURCE:
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
I dont have bluetooth in my laptop.
some laptops come with bluetooth modules available some dont.
assuming the bluetooth module is avaliable:
  1. switch on you wireless adapter
  2. check for programs or utilities that managers your wireless
  3. check if the setting for bluetooth and set to on or enabled
  4. you might need to set it to discoverable if you need to search and and send some files to you lap
then assuming that Bluetooth module is not available:
  1. you need to buy bluetooth adapters that you will plug and play
  2. install the neccessary drivers and utility programs
  3. then follow the above steps
Jan 16, 2013 | Compaq Computers & Internet
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Aug 15, 2011 | Lexmark P350 InkJet Photo Printer
I can't download the pictures off my pantech cell phone
You can connect your Pantech Link to your Windows 7 computer using the phone's built-in Bluetooth adapter. If your computer doesn't have a Bluetooth adapter bulit-in, you can connect the phone via a USB port. Once you connect your Link to your computer, you can use the phone as a modem, or transfer files back and forth between the phone and the computer.
Press the "Menu" key on the Pantech Link and select "Settings."
Open "Connectivity" and choose "Bluetooth," then "Activation." Set the option to "On" and press "Select."
Click "Back" and open "Visibility." Click "Show" and press "Select."
Click "Start" on the PC task bar, then click "Devices and Printers."
Right-click on your Bluetooth adapter and left-click "Bluetooth Settings." Check the box labeled "Allow Bluetooth Devices to Find This Computer" and click the "OK" button.
Click "Add a device" at the top of the screen. A new window pop ups, showing the nearby Bluetooth devices.
Highlight the Pantech Link and click "Next." A random number appears on the next screen.
Wait for the Pantech Link to prompt you for the number, then type the number into the phone and press "Select" to finish the pairing process.
Right-click on the Bluetooth adapter on the computer and left-click "Bluetooth Settings." Uncheck the "Allow Bluetooth Devices to Find This Computer" box and press the "OK" button. This prevents the computer from showing on other Bluetooth devices.
Regards.
Jun 18, 2011 | Cell Phones
Acer laptop cannot conect to handphone.
Check in your device manager to see if your bluetooth device is enabled. Also check in the Bios settings and in your power management to see if there are any settings there for the bluetooth.
If there are no entries for bluetooth in device manager, you may need to buy a USB bluetooth adapter. I know that some models of Acer laptops are bluetooth capable, but do not have the internal bluetooth adapter.
Jan 15, 2010 | Acer Computers & Internet
Does the hp 550 have bluetooth set up on it ?
no you need to buy a bluetooth adapter its only an emulator that is installed at factory and theese are usually useless gd news is a adapter is only about £10 from argos
Oct 02, 2009 | Computers & Internet
Faisad
Welcome to fixya
try this first if does not work plz let us know
Set up a Bluetooth enabled deviceTo set up a Bluetooth enabled device, you need to do three things:
  1. Add a Bluetooth adapter to your computer.
    This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
  2. Set up the device so that your computer can find it.
    To do this, you must:
    • Turn the device on.
    • Make it discoverable.
    To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer’s website.
  3. Install the device.
    To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
    To install a Bluetooth enabled device
    1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    2. Click Add, and then follow the instructions.
    hope this helps out have a great day:)
Jul 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
File transter
There will be a setting in bluetooth on the pc that enables files to be sent as your pc to phone transfer will be set at do not show this computer.
Sep 25, 2007 | Dell USB BLUETOOTH DONGLE CLASS I...
Bluetooth
you have to make sure within the bluetooth settings on your pc that your pc is discoverable, this is turned off by default, if you are using the software that came with the adapter it must be in the connection settings somehere
May 28, 2007 | Motorola Mobility PC850 Wireless Bluetooth...
Panasonic VIERA TC-P55ST50 55 in. 3D Plasma HDTV Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
