How do I move apps, pics, etc to SD card? Internal storage is full
For Android users, get the app Android Assistant and run it, use the Tools tab and choose the tool named "APP2SD" and choose an app from the list. When the app description appears, click on the STORAGE button and then click on CHANGE and click on SD to move the app from "Internal" to "SD card". Wait for the app to finish being moved, then back out to the list of apps that can still be moved to the SD card and do the next app. Be aware that when apps get updated, they will move back to the internal memory, so I usually check with APP2SD about once a week and move things as needed to my SD card. For space on my SD card, I chose a 128GB micro SD card and I've only filled it about 1/4th of the way over the past year. This is the safest way to move things because Android Assistant will only list the apps that can be safely moved to the SD card. Some built-in phone apps must stay on the phone's internal memory to keep working, and those cannot be moved and won't be shown by the APP2SD tool.
The Android Assistant also has a "Cache Clear" option on the Monitor tab that helps free up internal memory on your phone when you run it (cache clear). The app (Android Assistant) may tell you it needs access to stuff so it can clear the cache. Do what it says to give it access, then go back and tell it to clear cache and it will free up some more internal memory. Cache items will be refilled as and when each app gets used, so if memory runs short again, you might need to do this "as-needed".
I paid the cheap price for Android Assistant Pro so I wouldn't accidentally click on advertisements that pay for the free version. It find the app very helpful.
TIP: You can also set MANY apps to PUT their things directly to the SD card instead of internal memory! Yay! I did this with my camera app and it REALLY helps by having photos and videos sent directly to the SD card so I don't have to keep moving them around.
