I'm trying to hook up blue ray dvd player to tv.and also to set up net flix. not smart tv do you have adapter to switch to smart tv?
No, but most Blu-ray players are "smart" players and include a Netflix app as well as other services such as HULU, Amazon, etc. Usually, the Blu-ray player will have stickers or or emblems printed on the box or the on the player itself with "Netflix" , etc.
Connect the Blu-ray player to the TV using an HDMI cable. Connect the Blu-ray player to your router/home network with an ethernet cable or wirelessly if your player has built-in Wi-fi. Once that is done you can go to the Main Menu on the player and select Netflix. That should open the Netflix app and connect you for watching Netflix.
SOURCE: HDMi cable hooked up, but I get an
you have to go to the input button on the remote and push HDMI
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
SOURCE: My Panasonic Viera 50" 1080i
The Panasonic doesn't detect the presence of the signal on the antenna input so it just skips it. shut down the player and turn the cable box on before attempting to switch sources.
But why aren't you using the Composite RCA connection on the cable box ? Not only you would get a much better image but the tv would detect that change in the AV source and should switch by itself. If it doesn't then the control processor is faulty and the entire mainboard will will have to be replaced
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
SOURCE: Need activation code for Netflix. I own a Samsung
after you have Samsungs logo too activate for TV, it will have a code already for you on t.v. screen...now on your laptop,desktop, etc. copy and paste the link below to browser, and you will/or should be at the code app box. fill in TV number, enter,....and you will see TV asking for you too accept or decline "pairing" it should b cool 4 cats!(Bonnie Scotland for ever!)https://accounts.google.com/o/oauth2/device/usercode
