Press the Menu or
Menu/Set key. Then
Fax,
Miscellaneous and Compatibility.
Press the Up or Down key until you can
select Basic. Basic reduces the
modem speed to 9600 bps.
Press OK or
Menu/Set or Set key.
Press Stop/Exit.
Note these instructions should work for the
following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C,
Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C,
MFC-3340c, and most other MFC models.
Press the Menu or
Menu/Set key. Then
Fax,
Press OK or
Press Stop/Exit.
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Enter Maintenance Mode: 1.Unplug power from rear of Fax machine, hold the Menu button while plugging power back in.Continue to hold the Menu button until "Maintenance" appears in the LCD window. 2.There are no helps for the Maintenance mode.Follow parameter change procedures to the letter. Changing Baud Rate from Automatic to 9600: 1.Enter 10 (one, zero).This will bring up WSW00 on the LCD window. 2.Change the 00 to 19.If the baud rate is set to automatic, the numbers that appear will be 11100010. 3.Change the 11100010 to 01100010.This sets the baud rate to 9600. 4.Press the "Set" button just below the LCD window. 5.Press "Stop". 6.Enter 99.This will exit Maintenance mode and make the fax ready to use again.
hello, make sure there is paper in machine, turn machine off, hold the paper feed button, turn machine on, it will print the configuration of machine. adjust serial port setting on computer for baud rate. to change the baud rate on printer, you will need the user guide.
You have to change it on both side! If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800) Have you done it?
Most devices DEFAULT settings are 9600 baud rate, N, stopbit1. But you can change it depending on the device...
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
Enter the parameter ____ on the key board and press the Check Mark.
159 - Receiving Fax baud rate
153 - Transmitting Fax baud rate
The screen will read Cfg param val: 26
Enter in the value ____ and then press the Check Mark .
0 = V.17 14400
2 = V.17 9600
6 = V.29 9600
10 = V.27 2400
Screen will read Test -001+
Press the Reset button until you get back to Ready
