Sanyo DP50747 50 in. Plasma TV Logo
B
Bennyb81 Posted on Dec 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
50 sanyo hdtv model dp50747 with a black bar or colored lines about 1 wide down left side of screen. I have checked all the ribbon cables and made sure all were tight and good conection. What next?
oldgar9
Level 3:
Master:
  • Master 488 Answers
  • Posted on Feb 03, 2016
oldgar9
Master
Level 3:
Master:
Answers
488
Questions
0
Helped
124657
Points
1174
Definitely drivers, and may or may not be repairable. Here is what I understand. It depends on how the plasma panel in that set was made. Some panels have the X-drivers on a separate board. Others bond the drivers to the plastic ribbon connected to the panel. If it's a separate board, the board can be replaced. If it's bonded to the ribbon, it's virtually impossible to replace the defective chip.
5 Related Answers
Anonymous
  • Posted on Jan 24, 2008
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Anonymous
  • Posted on Apr 01, 2009
SOURCE: ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
A
Anonymous
  • Posted on Feb 11, 2011
SOURCE: sanyo plasma hd tv 50 inch screen i am trying to
Hi, take out the dvd player from port 1 and try the Wii in port 2 or 3 if the picture is good on the wii then you will need to get a 1 way scart lead for the DVD, not a fully populated one as these can cause interference between video inputs.
Hope this helps
Anonymous
  • Posted on Mar 05, 2011
SOURCE: what does the power fuse on Sanyo HDTV Model # DP50747 look like
got a 52 sanyo hdtv and it will not turn on anybody know the problem
Anonymous
  • Posted on May 03, 2011
SOURCE: sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Sanyo DP50747 with 1 inch vertical multi color bar full width 1/3 of the way in from the right side of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dp50747 has vertical 2 inch wide black row with a green line up the center, which card might be at fault? thanks
If you have JUST two green lines then your choices are between the buffer boards, YSUS board (all boards on the LEFT side of the TV when looking from the back) and , less likely, the main or plasma controller board. I'd really focus on the first two.
if you have two lines ON TOP of otherwise normal picture then you most likely have a bad panel, specifically the address register ICs embedded in the display's fabric underneath the display ... there's no solution to that I'm afraid.
www.coppelltvrepair.com
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Brand new out of box lines down right side of screen like 6-8 different colors from top to bottom.
My best advise is to Return it NOW ! Plasma sets only a expectancy of non repair for only 2-3 yrs. I would exchange it for an LCD version.
3helpful
3answers
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
2answers
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
2answers
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
3helpful
4answers
Ysus board number for a sanyo 50'' plasma model dp50747
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
