I had a car once that did that . The cause in that case was worn out shock absorbers both sides.
1. What brand and model of tire was fitted?
2. Please describe the wear pattern on the front tires in more detail. For example is the excessive tread wear.....
A. Right across the face of the tread on each tire or
B. On the outside edges of the tread on each tire or
C. on the inside edges of the tread on each tire or
D. on both sides of the tread but not on the center section of the tread on both tires.
B is normally caused by incorrect toe setting - toe in
C is also normally caused by incorrect toe setting - toe out
D is normally caused by tire pressure set way too low.
Faulty steering and suspension components can also cause abnormal tire wear for any component that affects the wheel alignment settings.
If you can provide a better description of the tire wear on each front tire you will get a better answer.
