What dies the bypass air take do
Description & Operation
Not for Dodge Stratus Sedan
The idle air control motor (IAC) attaches to the throttle body. It is an electric stepper motor. The PCM adjusts engine idle speed through the idle air control motor to compensate for engine load, coolant temperature or barometric pressure changes. The throttle body has an air bypass passage that provides air for the engine during closed throttle idle. The idle air control motor pintle protrudes into the air bypass passage and regulates airflow through it.
The PCM adjusts engine idle speed by moving the IAC motor pintle in and out of the bypass passage. The adjustments are based on inputs the PCM receives. The inputs are from the throttle position sensor, crankshaft position sensor, coolant temperature sensor, MAP sensor, vehicle speed sensor and various switch operations (brake, park/neutral, air conditioning).
Fig.
When engine rpm is above idle speed, the IAC is used for the following functions:
Off-idle dashpot
Deceleration air flow control
A/C compressor load control (also opens the passage slightly before the compressor is engaged so that the engine rpm does not dip down when the compressor engages)
Fig.
Off-idle dashpot
Target Idle
Target idle is determined by the following inputs:
Gear position ECT Sensor
Battery voltage
Ambient/Battery Temperature Sensor
VSS
TPS
MAP Sensor
Battery voltage
VSS
TPS
MAP Sensor
Removal & Installation
Fig.
