Cold/warm/hot lights flashing
Hello there and welcome to fixya:
Is there any way you can provide me with the model number of this unit so i can give you the best possiable solution.
I am fairly sure it is the FILL VALVE however i need the model number to ensure that i give you the proper testing and repair information ok
So please provide me with this information
Best regards michael
SOURCE: washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
SOURCE: washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
SOURCE: Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
SOURCE: Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
