Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Can I remove the white crisper drawer fronts to clean.
Spills have entered the front of the drawers between the clear plastic and the white fronts that I cannot get at and has started to mold. Looks like the fronts could come off because they are separate but don't want to force and break the plastic
6ya staff
SOURCE:
Anonymous
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
jumptrout51
steve
  • 3361 Answers
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Posted on Feb 21, 2009
Bat1956
Bruce Volkers
  • 585 Answers
SOURCE: removing refridgerator grill
Look at the top slots in the grille. If there is a slight cutaway near the ends that is where the release tabs should be. If no release tabs, try a gentle lifting pressure in the grille as you try to pull away. They are made to be removed by the user. Check the manual if you can find it. If no luck, reply, I'll see if I can find one.
Posted on May 28, 2009
David Shaub
  • 2976 Answers
SOURCE: Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Posted on Jul 01, 2009
Wonder Wizar
Anjoy Kumar Roy
  • 62 Answers
SOURCE: vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Posted on Jan 21, 2011
I'm trying to clean the top of the pantry drawer in my 795-72053 refrigerator. Liquid has seeped between the clear plastic and the white. How can I remove this piece to clean it?
You have two drawers side by side that are called the crisper bins and one long drawer at the bottom typically called the deli drawer. I think what you are asking is how to separate the front (clear part) of the drawer from the back (white part) ,right?
Usually there are snap tabs that need to be pushed in to release the two pieces but I need to say that they are very fragile and break quite easily so be careful!
I would try soaking the drawer to get whatever it is cleared from it and let it dry completely. Keep in mind that there is usually a left and right specific drawer so if it doesn't fit then do not force it!
Jan 28, 2018 | Refrigerators
Something has slipped behind the bottom drawer, a flimsy cutting board. Can the drawer be removed and how?
The drawer is easily removed. Make sure you switch off the power first and I always unplug just to be sure.
9.1 Drawer Front Removal
9.1.1 Slide open drawer.
9.1.2 Locate draw pin on either side of the tub. (These are white plastic pins, about 1.5cm diameter. You can't miss them.)
9.1.3 Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this.
Note: The pin web is vertical.
9.1.4 With both pins removed the bottom of the drawer front can now be eased out slightly.
9.1.5 Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
9.1.6 Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
9.1.7 Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is
vertical.
9.2 Tub Removal
9.2.1 Open the drawer fully.
9.2.2 Depress the right-hand tub clip and push it back about 30mm (1 inch). Repeat for the left-hand side. These clips are on the runners and are usually white plastic.
9.2.3 The tub may now be lifted up off the drawer runners. It's amazing but the drawer simply lifts out.
9.2.4 Slide both runners back into the product.
9.2.5 Refit in reverse manner.
Feb 18, 2015 | Fisher and Paykel Dishwashers
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
How do I take apart crisper drawer?
usually the drawers just lift out when pulled as far as you can .lift front edge
Jul 23, 2014 | KitchenAid Refrigerators
How to completely clean the Crisper drawer
I don't know if you've already figured out how to remove the front panel on your refrigerator crisper bin, but here it is. Once the drawer is removed, pull back those clips on the top left & right of the front of the drawer.Just hold the side and pull back at the same time, then you can remove it. Once both side have been released you should be able to remove the clear plastic front and clean both pieces. I hope that is clear enough. Best of luck, unless of course you've already discovered the answer yourself.
Feb 21, 2010 | KitchenAid Refrigerators
How to clean crisper drawers humidity control slider?
Hello. Remove the entire drawer and put it in a large plastic bag. Add two cups of ammonia and close the bag up tight with a twist tie. Leave the bag in a sink or a tub or out doors in case it leaks. The next day remove the drawer, rinse it thoroughly to remove the ammonia smell and the slider will be as clean as it is going to get. Regards, Joe
PS - kindly rate my answer as helpful. Thank you.
Feb 12, 2010 | Refrigerators
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
I can't get the crisper drawer out on my electrolux fridge
Just a suggestion... on mine I need to hold open the top of drawer "plastic flap", and lift front up and down while trying to remove gently. Too hard and you will find the plastic is brittle. (trying to replace is also a challenge).
Apr 21, 2008 | Refrigerators
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
600 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
