Its black with 3 antenna's.
You need to reset it to factory default by pressing the reset button for around 5 seconds. Once it is reset, the username and password is admin/admin.
Or if you are a careful guy, you have backup your configuration in your PC, there is a software to read the configuration and extract the password for you.
Good luck
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
