My Tatumg 42 inch TV is stuck on standby cannot turn on with remote or on Tv
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
