c
curtis Posted on Dec 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why did amp indicate error and turn off? - Pioneer Audio Players & Recorders
Claude Kayser
Level 3:
Top Expert:
  • Pioneer Master 9,098 Answers
  • Posted on Dec 26, 2015
Claude Kayser
Pioneer Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067429
Points
28436
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
I have a Mitsubishi 73 dlp when i turn on the tv it works for about a min and turns off status indicator blinks once red then 7 short yellow
looks like you have error code 17, which indicates you have
A) loss of 12volts from PWB-power pcb to light engine
B)Loose PE or PE2 connector
C) Engine failure.
light engine part# would depend on your model#, but first check your PE & PE2 connections, & make sure you have you 12volts DC from poer board to light engine.
Same taco
This is an error code indicating failure of some board and might need attention by a qualified service technician.
Error 8:11 HP Designjet T1100ps 44in PS3
Error indicates Formatter,Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part..
d4wd6icgpc9laaaaaelftksuqmcc
nloqafiqpfr0pqy6fgsl6z+nlcjwrqeuxlt5siey8sjpc+feblil6+xgwjruzafracof0e359teuwi1ozhlmhrx0xfmcd+bfeilmn5l+ppik2hpic6wgwvpqfwee1yw0nvg1qi9vzo58bnigp4octvkvtsy87834sjn6odbsmoha2eycmv8comsjb7raqh4aaaaasuvork5cyii=
2answers
When I turn on my plotter error message system error 08:11
* indicates "on"
# indicates "off"
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
1helpful
Hp designjet 500 plus 24"
HEYA
This error indicates that there is a problem in the Service Station Assembly (SVS). Either you have a paper left-over after a paper jam thats blocking the movement of the mechanism of the SVS or sometimes ink mounds around the Station if yes try cleaning it, or it could be a transient error that entails to turn the plotter off for a while and then turn it back on. If problem reappears and you are familiar in this plotter disassembly, check manually while the plotter is OFF the motion of the SVS gears; you can figure out the smooth movement.
In worst cases if problem persists i have to tell you that replacement of the SVS might solve your problem.
Hope this fixes your problem if not please reply
LONG LIVE THE GEEKS!!
ERROR CODE 18:10
* indicates "on"
# indicates "off"
2helpful
3answers
How do you retieve the error codes?
All Mitsubishi DLP Televisions have a built in Diagnostic Decoder to store the last fault in memory. This will help the Mitsubishi Technician determine what area or part defect could exsist due to your television not coming on or turning off by itself. In order to read the error code from the front panel lights, you need to know how to access this information if it is available.
Please remember not to unplug the tv from the power outlet because this will reset the error code. The television must be in the power off state or shut off state to retreive the code.
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check.
Pressing the front panel “ACTIVITY” and “CHANNEL DOWN v” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no
problem has occurred since the last usage.
Note: The front panel buttons must be used, NOT those on the Remote Control. • The number of flashes indicates the value of the MSD (tens digit) of the Error Code. • The flashing then pauses for approximately 1/2 second. • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. • The Error Code is repeated a total of 5 times.
Example: If the Error Code is “23”, the LED will flash two times, pause, and then flash three times, then this will repeat itself for four more times before the blinking stops. If you forget the code, you can start all over again after the LEDs have stopped blinking. Just remember you are looking for a two digit code, denoted by a pause in the middle.
Example: You are watching Television and after 20 seconds it shuts off with no picture or sound. By pressing on the front panel the INPUT and MENU at the same time starts the Diagnostic Procedure, and the TIMER LED will then blink six times, and then a small pause, then six more times. This is an error code of 66, and will indicate to the Technician a defect in the lamp ignition circuitry. This will help us to order parts for the repairs without guess work.
In addition to the above code retrieval procedure- most new Mitsubishi LCD & DLP televisions have a built in Error Code Log or menu system. To access this feature the television has to be on and have a picture or blue screen to read this fault menu . To read this Error Log in the television you have to use the Mitsubishi remote control and follow this procedure: Press & release the Menu button, followed by 3564 on the remote control. You will see Lamp time, Code & Status. If an error has happened, please read the numbers indicated under Code to our service person or office staff. We can determine by these codes how to handle service on your unit.
When I turn On the digital camera It indicates "System Error". There is some solution? Thanks a lot.
Turn camera off, remove
and reinsert batteries,
and turn camera on. If
error persists, contact
retailer or Nikon repre-
sentative.
Technical Support
8AM - 2AM (Eastern)
7 days a week
1-800-Nikon-UX
1-800-645-6689
Have your product, serial number, and computer (if applicable) available
http://support.nikontech.com/app/answers/detail/a_id/238
1helpful
Mp630 error code 5100 turned of as recommended same problem recurs
turning off the error code does not remedie the proble you will need to find out what fault the code indicates & replace the offending part
1helpful
935 Service Printhead Error
This error indicates that the Printhead ( Laser Scanner ) is defective. Sometimes turning the printer off for a little & then turning it back on, gets rid of the error but it will usually return. The printhead is situated at the top of the printer under the top cover. It will need to be replaced.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
