Watches Logo
S
Sharon Cramer Posted on Dec 26, 2015
Not working . Never worked. Dead battery? Which kind?
1helpful
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gerald_b9936683ef6d97c6
The hands on my watch are not working. i assume the battery is dead???
yes your watch battery is dead and it has to be replaced by a new one. i hope i had been helped you.
Hi i have a t-touch and i saw that the battery is Q/eol (end of life)...what do they want to say with it? If the battery dies the watch does too?
mcdevito75 here, I doubt very much it means end of life, unless it is actaully written on the watch or battery, Most Battery watches have access to change a dead battery, BUT!! there are sealed case battery watches too, these kind you find in vending machines, at McDonalds as giveaways etc.
Jun 24, 2010 • Watches
2answers
Watch not working
Synchronization of the chronograph hand do not affect any watch movement to work properly and it is ment for correct time measuring only.
If your watch does not work properly there is some kind of fault in it and you will need to see a watchmaker to diagnoze it.
2helpful
New watch has stopped
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead or dying battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement or somehow damaged the movement through usage and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Jan 13, 2009 • Watches
Can't get my croton watch to work.
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
New fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Dec 05, 2007 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
