Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
i don't think there is a pan in your machine,it's built into the bottom frame near the compressor where the water evaporates from the heat.most likely you have a blocked drain in the freezer or one of the water lines has a crack or the water valve is cracked and leaking.open the freezer door,look at the floor of the freezer to see if there's any ice there on the freezer floor,if so you have a blocked drain,where is the water leaking from,in the front of the machine or the rear,also do you have a water line hooked up to the machine?
If your water supply line is copper, check to see if it is corroded inside the line. It sounds like copper sulfate or copper chloride in the water supply. If it is corrosion build up try replacing the supply line.
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
