My Canon PIXMA ip 1500 prints blank pages. I went to maintenance menu and tried several cleaning functions but still can't get it to print at all. I also checked the ink cartridges. The manual gives all kinds of troublshooting about different types of printing problems but nothing about printing blank pages.
Now, look at the possible reasons behind the Canon printer printing blank pages issues are follows:
·There is some default in hardware of Canon PIXMA1500 printer.
·This issue can be arises due to a cartridge failure.
·Low ink levels can be one of the fundamental causes behind this issue.
·Some software can be the reason.
·Sometimes, printer drivers cause issues
·The issue can be with the device that you are using for printing other than printer.
Follow the below points to solve the Canon PIXMA1500 printer printing black pages issues:
Inspect cartridge
·Make sure to install the ink or toner cartridges properly within your Canon PIXMA1500 printer by following the steps given in the installation manual.
·Eradicate the protective sheet or round covering of the former otherwise this will hamper your work and Canon PIXMA1500 printer printing blank pages error may crop up.
Check ink level
·In case of your ink cartridge is empty, then your printer obviously print blank pages. You can easily check the level of ink by observing the menu buttons present in your printer.
Unclog the print heads
·Generally, this issue arises when you have not utilized your Canon PIXMA1500 printer for a long time. The ink dried up and blocks the print heads. At that time, by using lint-free soft cloth you need to clear print heads or you can try automatic cleaning method to clean dirty or clogged print heads.
Try updating the Printer Drivers
·When the printer driver is outdated, it may cause the issue. So, make sure to keep your driver always up-to-date.
If the issue still continues to keep up, then make a call at Canon PIXMA1500 Printer Customer Service Number and get united with proficient technicians. These tech experts will be always by side until you are able to resolve the issue on your own.
One of the most common reasons by which users get the Canon Printer Printing Blank Pages errors is the blank ink cartridge. As it is impossible to print without ink users need to make sure that there is always enough ink present in the cartridge to print the desired files and documents. Follow the blog for more.
Canon Printer Printing Blank Pages Error can be arises due to a cartridge failure or Low ink levels. We offer online support to Printers Customers for any issue.
Follow the Link Below.
Here are few steps to solve the canon printer printing blanks pages error:
1. Replace the ink cartridges and Toner: The first step you have to perform is to replace ink cartridges and toner. Sometimes the ink cartridge and toner may be dry, due to dryness it is difficult for printing.
2. Unclog the Printer-head: Sometimes our printer is not in use for a long time, so due to this reason it clogs the printer head. So unclog your printer-head fast.
3. Empty Cartridges: check how much ink is available in ink cartridges. Sometimes we forget to fill the ink and it creates the error like a canon printer prints blank pages.
4. Update printer driver: Update your printer driver and enjoy hassle free printing.
These are some steps that will help you in solving the error.
