Question about Watches
How do I change the backlight setting? - Watches
    Top Expert:
  • 9,098 Answers
How to adjust the backlight strength, time-out length of the ...
www.cnet.com > Mobile > Wearable Tech
CNETJul 23, 2015 - In order to adjust either setting, your Pebble Time watch will need to be updated to version 3.2. Launch the Pebble Time app on your device ...
how do i adjust backlight time on my iphone ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Nov 18, 2012 - Not sure what you mean by Backlight time. But you can adjust how long it is before your phone auto locks at. Settings> General > Autolock. How do in change my backlight settings on my iP...
Dec 31, 2013
Did they do away with the backlight timer for i...
Nov 6, 2011
how do change the back light to time out?
Jan 14, 2009
More results from discussions.apple.com
Posted on Dec 26, 2015
SOURCE:
I have a black and dark grey digital watch marked TCM on the back with 4 buttons saying "bearing", "start/spl", "mode/select", "stp/light/set" around a circular digital face. On the back it says that it...
  1. Hold and press upper left. (backlight turns up and cipher (to adjust) start blinking)
  2. Switch between the positions by pressing bottom left
  3. Set the cypher you want by pressing bottom left
  4. Repeat step 2 and 3 each time you need
  5. Press upper left to end of adjusting
To use the compass - upper right. To callibrate and set the declination, please search it. I just post that answer to another TCM 217362 watch owner.
Oct 21, 2010 | Watches
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
Casio F91W-1 Wrist Watch- backlight color
You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
May 06, 2010 | Casio F91W-1 Wrist Watch
Backlight on DW6900
You cannot change the light. It is an electro-luminescence layer behind the display. It is something like a large LED. They are designed to not be very bright to save battery life. I have a number of Casio watches. They are all not very bright. Also the non silver background type watches tend to be much darker than the silver background with black symbols.
Jan 29, 2018 | Casio GShock GShock Youth Culture Theme s...
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Setting date and time
I don't know how much significance this post would make to any now, but I was playing with the watch trying to figure out how to set the time and I have figured it out...
1. Hold the "Adjust" button until where it displays the day of the week starts blinking (This will display the major airport in your area to determine your time zone, mine is "LAX"...to change this, while it is still blinging press either "Time Memo" or "Recieve" to move up or down)
2. Press "Adjust" again so you see "12H" (I guess meaning 12 hour intervals)
3. Press "Mode" (at this point your seconds will start blinking) to change these, againg press "Time Memo" or "Recieve" to move up or down. (usually I skip past the seconds)
4. Repeat step 3 to do your hours, minutes, year, then the date...(order is as follows)
5. When you are done press "Adjust" then everything will stop blinking, and you are done
This is as much as I figured out and I hope this is helpful to anyone that needs it...
Nov 28, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Automatic backlight
PUSH AND HOLD THE MANUAL LIGHT BUTTON, SHOULD CHANGE TO AUTO MODE
Oct 21, 2007 | Casio G-Shock GW500A-1V Wrist Watch
Watches Logo
188 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
