Question about Universal MX-900 Remote Control
The Button under WATCH does not bring up the CABLE TV. The DVD is on the TV screen whether I use the cable button or the dvd button.
Both the DVD and CABLE are on Video 5 in the set up
Why has my Alba TV Screen say no Sygnal
how is youre cable connected to the 1-tv 2-cd/dvd player 3-amplifier, coming from satelitte..If you watch a dvd, somtimes you half to push the tv.video button on the dvd remote control just once to allow the tv cable signal to pass to the tv. each time you watch a dvd it blocks the tv signal. this is normally true unless you have a special wiring configuration
Aug 30, 2014 | Albatron Computers & Internet
No picture just blue screen
Check your settings button. Most remotes have a video source button...if this button has been pressed, then the tv is probably trying to show you the video screen. On my remote, pushing the button 3 times brings it to the dvd screen. Pushing it twice brings it to cable tv...etc.
Your button may be labelled as something other than video source.
Nov 03, 2013 | Televison & Video
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
I just got a rca tv mdl# f36668 36" it didnt come with the remote.my ? is how do i watch a dvd in it
the easy way is to buy a universal remote
the cost is around 8-10 dollars
Aug 15, 2009 | RCA F36668 36" TV
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Zenith SMS1943S made 1995 Need code to switch to dvd status
nleebrooks,
1) check the RCA cable connection from your DVD to TV screen.
make sure that each cable is in the right place (for DVD player yellow cable = video/ red and white cable = audio) (TV screen: yellow cable = video IN /white and red = audio IN
2) from your TV screen locate and check for A/V IN socket. it's either at the back/front or side of the screen.
note: some of TV screen does have 2 A/V inputs
3) Facing the front of your TV screen, locate a button indicating "A/V" or "AV" or a box picture having a forward arrow inside.
note: if you locate the said button and your screen have 2 A/V inputs press the said button until the right input where you connect your dvd cable been set.
cheers,
mark
Jan 17, 2009 | Zenith C13A05LG 13" TV
Hitachi P42H401
Maryann,
You should have an RCA cable connector with your DVD player (three wire connector color coded yellow, red, white). If you plug one end of that into your DVD player (out) and into the input #1 in the back of your TV that should be sufficient. Then just select from the input menu on your Tv to watch that input. You do this by the buttons on the lower left of the TV. One is marked "input/exit". Pressing that button should bring-up your input menu then use "menu/select" button to select input 1 and try playing the DVD...
I do have the owner and service manual if you need it just let me know...
Bill
premtech@willapabay.org
Jan 27, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Oct 30, 2007 | iLO DVD Recorder DVDR05
Can't find a channel to watch a DVD pre-recorded DVD
you should have a input select button on your remote. video 1 should be the front and video 2 should be the back. i had to buy 3 or 4 different universal remotes when mine messed up just to get the one button to change to change it to the inputs because there is no other way to change it to that with he buttons on the tv. kinda surprised that you didn't try and push that button yet.
Aug 31, 2007 | Televison & Video
Universal MX-900 Remote Control Logo
78 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
