HP LaserJet 2840 All-In-One Printer Logo
a
anthony pierre louis Posted on Dec 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2840 laser printer only prints on right side and nothing on left side
Orn Wilson
Level 2:
Scholar:
  • Expert 104 Answers
  • Posted on Sep 22, 2017
Orn Wilson
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
73158
Points
203
If the image defect is a fade from right to left or left to right then there is probably something broken on the secondary transfer roller (one side lifting and the other not). If there is a straight edge line and the image is blocked then there is probably something blocking the laser scanner. Good Luck
Claude Kayser
Level 3:
Top Expert:
  • HP Master 9,098 Answers
  • Posted on Dec 25, 2015
Claude Kayser
HP Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066582
Points
28436
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
2answers
Hp laserjet 2840 not printing
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-2840-prints-blank-pages-or-yellow-only/td-p/2326639#.Ur1kMH_lMgU
How do I align the caracel of HP 2840 all in one
Other than tec guy are not advisable to do this exercise :Corosol align disturbed,open the printer up to corosol mechanism check rotary swing shaft left and right gears, there are markings which was exactly matching with rotary right & left disc markings. If its disturbed print quality issue will developed. If you have service manual read carefully before opening the printer.. Best of luck.
Hp color laser jet 2840 not printing on left side
My hp 2840 all in one laser jet printer squeaks when it is printing. How do I lubricate my 2840 HP laser jet printer?
Corosol technology is older,slower sounds also too high, it is not suggestible to lubricate the moving parts because of cartrides will move while printing result lot of toner particles raises in printer chamber,if this particles deposited on lubricated area will abstract the moving spares. If you can do the periodical maintenance, use silicon grease for moving parts..
3helpful
2answers
2840 only prints on right side
If you are a bit adventurous and a bit patient, you perhaps can fix this yourself, and not require any disassembling. It worked for me on a similar 'carousel' unit... hp2550L.
For extra info, check this post out. http://www . fixyourownprinter . com/forums/laser/40284 (remove spaces)
If you look closely at the spot where a toner cartridge slips into a slot of sorts, you might see left side aligned and right side just a little off of 'good alignment' for that slot. What I did is to pull on the top of the black-plastic gear. Pull it toward the center of the printer.
There is a small, white gear at the very top of the black gear (not easy to see at first). By this pulling and bending of the black-plastic gear, you can get the gear teeth free of the white gear --- for just a moment. Just enough for the gear teeth to free-up and find their proper place. It doesn't take much.
When done, take a breadth and relax. Turn power off/on, and try it out.
1helpful
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
MY HP 2840 IS ONLY PRINTING ON THR RIGHT SIDE, What could be the problem?
this is a typical problem.. this printer uses a carasol meaning that the toners are riding on a carasol there are 2 white gears that drive the carasol 1 on the right and one on the left. Half page fade is almost always a misaligned carousel! A Tech is needed or a service manual here is a link for the manual http://www.partshere.com/Models/Q3948A/CLJ_2820_Removal_replacement.pdf
look at figure 5-78 Removing the print-cartridge carousel you will see the white gears im talking about
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
1helpful
2answers
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
1helpful
Printing on right side only
It is the carousel that is dislocated. Check the alignment if it's brooken
k24674
Grand Canyon Tech
Grand Canyon Tech
