KLH R7000 Receiver Logo
M
Millie Johnson Posted on Dec 25, 2015
How do I hook up a non powered subwoofer? - KLH R7000 Receiver
How do I hook up a bose subwoofer in a non bose 2000 Cadillac seville sls?
I would hook up an amplifier first, then hook the sub up to the amp.
tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
How do you power up the sattelite speakers without the subwoofer?
Depends on the type of sound system. Some require you to hook up to the subwoofer then the subwoofer to the sound system, others are just a direct line in to the sound system (in which case simply un hook the sub woofer. If it requires hook ups to the woofer, see if you can turn the volume down on the woofer directly.
How to hook up emerson subwoofer sw 03
For powered sub :If your receiver has a sub woofer output on female RCA plug, that is the way to go. If no output you will have to get a speaker line to line output converter to then connect to your subwoofer amp input.
Unpowered sub - just hook up across the speaker terminals for each channel making sure that you hook it up in phase.
Is it possible to hook the infinity bu-1 subwoofer to a home theater system where the subwoofer output is straight power say it"s like 25 watts coming out of that one channel and before the original...
In general higher speaker impedance is safer than lower impedance for the amp. Don't expect anything impressive re: audio output from a passive (unpowered) sub if your HTS says it pushes only 25 watts. Without frequency bandwidth and distortion noted the spec is virtually useless as a comparison.
The BU-1 is a powered sub that accepts either RCA Line Level or HIGH LEVEL amplifier power. If you use the latter, impedance is a non-issue because the input feeds the BU-1's internal amp, not the speaker directly. You should be okay.
Perhaps if we knew some specifics about the HTS we could do more than guess.
1helpful
How big/small can the Enclosure be on RIP210DVC Car Subwoofer
Specifications Key Features Type: Component Elements: 1-Way Function Subwoofer Size: 10" Powered: Non-Powered Nominal Power Handling: 500 Watt Technical Features Peak Power Handling: 1000 Watt Frequency Respond: 35 Hz - 2,200 Hz Sensitivity: 94 dB Impedance: 4 ohm Components Woofer Material: Paper Mounting: Enclosure: Non-Enclosed Top Mounting Depth: 5.5 in.
1helpful
Subwoofer: Active or non active?
Hello Smegboy,
Yes, you are right. This receiver is rated at 100WRMS output in all 5 channels (2-front, 1-center and 2-surround) while in Dolby Pro Logic operation. The subwoofer output is line level only (not amplified), which means you need a powered subwoofer to be connected to this output. A non-powered subwoofer could be used but, you need an additional amplifier connected to the subwwofer output from the receiver to drive it.
Let me know if this helps.
cancerags
2helpful
3answers
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Subwoofers
low power needs adequate ground
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
NOEL
NOEL
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
