SOURCE: LBP 2900 printer settings and number of pages printed
If you have this setup on a network cable, the User interface (IP address of printer) should allow you to see this in the admin panel.
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: [email protected]
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
SOURCE: printer says check cable. Cable checked is fine
Make sure the USB cable goes DIRECTLY to the computer and not via a USB hub or anything similar
Also try another cable preferably shorter if you can as not all USB cables are the same even though they should be.
Remove as many other USB devices as you can PRIOR to the above steps and then try.
Also double check you dont have two copies of the printer installed as this is another common error.
