Question about Razor Sport Mod
My scooter will only show the red light when on and it wont do anything
I charged it an while it is plugged in it will read that it is charged. when I unplug it, it wont show that it is charge or low. the only light that comes on is the red power light. it wont go or make any noises. but when its plugged in and you turn the throttle it makes a clicking noise. what could be wrong?
    Top Expert:
  • Razor Master
  • 12,962 Answers
Your battery is no good and needs to be replaced.
Posted on Dec 23, 2015
SOURCE:
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
Scooter wont go
It could be a battery connection, or maybe your key switch?
Or a connection problem between batteries and the motor controller
or the free wheel switch is on.
Apr 05, 2014 | Pride Mobility Products Celebrity X...
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Celebrity x scooter wont charge
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File + Print for future,hope this has helped,Colin.
Nov 22, 2011 | Health & Beauty
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
Hiya I have brought an E-Scooter V8 from ebay seller, I don't know how to use it do you need to turn it on to charge it can some explain in a fools guide how to use it thanks loads
1. get out the massive charge box you will need to plug it in the port on the side of the bike you will see a green light, then plug the charger in and turn it on the light should go red to show that it is charging, once it is charge 4 to 5 hours green light should appear, then unplug the recharger.
2. Then to get the scooter to go get the key put it in the key thing and switch it to on. The throtle is on the right hand side twist and scooter will move (note only to that once you on the scooter :P)
3. The breaks pretty easy i belive so i wont explain it
4. control pannel the L and R turn on the left and right indicator
the black button is the novelty horn
the little red switch is for the headlight
Mar 28, 2009 | Toys
Razor Sport Mod Logo
204 people viewed this question
Top Razor Health & Beauty Experts
Tom Chichester
Are you a Razor Health and Beauty Expert? Answer questions, earn points and help others
