Shopjimmy tests their boards but a main can be damaged if it's not handled properly, it's very sensitive to static damage. Remove the flat strips going from the tcon to the panel boards, clean them and look closely to be sure there isn't any bent or broken contacts, do the same with the LVDS cable going from main to tcon. Next thing to do is check the fuse on the tcon board, if it's blown don't order a new board but throw the set out as the panel is defective. If the fuse is ok I'd send the main back and get another one from shopjimmy as it sounds like this board is bad.
Can be the tcon board. First of all try to replace the tcon board.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
There is a high probability this is the tcon board, located at the back of the LCD controller.
I'll need the exact TV model number in order to be able to tell you what exactly the board number is.
It is not guaranteed - it may be the main board or, even worse, the LCD itself; not many people know, but the LCD dispay has quite some electronics literally inside it or glued to it in a totally unserviceable way.
If that electroncis burns out , the whole LCD goes to trash even if it's physically intact.
It's unfortunate, but not uncommon.
Still in your case replacing the tcon board is the first thing I'd try.
Ah, one more thing - sometims the cables that connect the tcon board to the LCD also burn and cause similar troubles. When replacing the tcon board that will become apparent.
