Disney Princess Toyota FJ Cruiser 12-Volt Battery-Powered Ride-On Logo
Connie Harvey Posted on Dec 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will start moving then quits. Makes a click noise. What can this be
Battery is charged. It will go for a minute, then no power. Sometimes it will then make a click sound and restart again
Phillip Hicks
Level 3:
  • Master 917 Answers
  • Posted on Jan 06, 2016
Phillip Hicks
Master
Level 3:
Answers
917
Questions
0
Helped
162418
Points
2822
Sound like a BAD connection between BATTERY & MOTOR
2answers
Turn key, makes clicking noise but not start.
Double check your battery connections. If the battery is new and the starter makes a series of clicking noises when the key is held in the start position than you are not getting a good power supply to the starter or there is not a sufficient ground.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Car wont start makes a clicking noise and resets the clock everytime
Does the battery have a good charge in it. Possible bad starter to.
Rattling noise and battery light on?
It may be the alternator bearing/bushing that is making the noise and may lead to alternator breakdown. This will result in battery not charging and the light on the dash coming on. You need to confirm this.
2008 cts will not start. not sure if it is battery because the lights on the inside come on . When the key is turned it just makes a clicking noise.
just get a jump start. if it starts properly. and it has at least 14 volts at battery while running. its a bad battery ! remove negative cable from battery while running. if alternator is not charging battery. engine will quit. if ok, replace or charge battery. good-day !
2answers
When i go to start my 92 yamaha fzr 600 it makes clicking noise
This usually indicates there is not enough power to turn the starter over, so the solenoid just clicks. It sounds like you need the battery to be charged. If this is occuring even after 20 to 30 minutes of riding, either the charging system is not working or the battery is bad (motorcycle batteries typically don't last for more than 3 years, less if they are not kept charged during the non-riding months).
3helpful
3answers
4helpful
2answers
Car wont start but the lights, radio and everything battery operated comes on but it just makes a click noise when trying to start engine
If you can hear a click (quite loud) from the engine compartment, but the starter won't crank, this also could be caused by discharged battery. Battery problems - Discharged or dead battery is one of the possible reasons for a car not to start. Very common is the situation when we forget to turn the lights off overnight (the dome light, for example), which causes the battery to drain. In this case when attempting to start a car, all you will probably hear will be a clicking noise - there won't be enough power to turn the starter. Here is the simple way to check if the battery is discharged: Turn the ignition on. With the engine off, turn the windshield wipers on. If they move way too slow, much slower than usual, the battery is probably discharged. Also look at the dashboard lights - if they appear very dim, the battery is probably discharged.
If the battery is relatively new, it can be recharged. All you need to do is to boost your car and let the engine run for a while to charge the battery.
However if your battery is more than three-four years old, you will probably need to buy a new one. Sometimes, an old battery may even die with no apparent reason, even if the day before it was OK.
If the battery is OK, the starter solenoid, starter cables or the starter motor itself could be a problem.
Check it and tell us news.
2helpful
2answers
02 Chevy Cavalier - Fast Clicking Noise When I Turn Key
your battery isnt holding enough charge to crank the starter.thats what the clicking is. try charging you battery for a good 8-10 hours, if it still does the same thing you'll need a new battery.
1helpful
2answers
1999 mercury cougar wont start
clicking usually sounds like a starter sometiimes when they start going bad it gets stuck that's why u only hear clicking, try tapping it with a steel bar or something it worked for me wen my car was doing that, and what u mentioned about the battery it might be that is not holding charge even if u try jump starting it
Top Walt Disney Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Walt Disney Vehicle Part and Accessory Expert? Answer questions, earn points and help others
