Is there a replaceable handle for this oven? Is there a hidden distributor that might have it?
SOURCE: Replacing a Dacor Microwave Over the Oven Door Handle for Model PMOR30
This Sharp-made Dacor model is equivalent to a Sharp R-1750-series and we have the complete service manual at our site:
http://www.microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
SOURCE: GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
SOURCE: Change Fuse Whirlpool Gold GH7155XHS1
no the control does not come off from behind.
what you will find is the top vent grill has to come off first. it has 2 phillips screws that hold it to the top of your unit.
you will find 4 screws on the top, go ahead and take all 4 out and then pull the grill out from the top and hinge outward to remove/ once the grill is off, then there is 1 more phillips screw that holds the control board/ touch panel to the frame. remove and then lift up then out on the panel.
now that you are into the unit, make sure you have UNPLUGGED it first. the fuse is about 1 1/4 inch long white ceramic material with metal ends. you can find a new one at a radio shack or get one online for your unit. r/s has them for cheap and if that allows the unit to run again, great, but...
there was something that caused the fuse to go bad. so dont be surprised if you need a diode or capacitor to fix why the fuse went bad.
SOURCE: replace door handle on mco153uq
Normally You have to
and then you'll see the previously hidden screw(s) you need to remove.
made) that demonstrates how it's done.
In some cases, you then
have to gently rotate the handle to unlock it.
You can order parts here.
We're
