SOURCE: Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
So here's what I did and it worked for me. Somehow the WinDriver that is on the software is uninstalling itself and needs to be listed with the drivers for Jungo for this software to work. I installed the software when I first got the machine with no problems, then suddenly I couldn't open it and was receiving the same connection error. When you go to http://www.futura-support.com/faq/machine.htm#2 to install the drivers, you'll notice their screen shot shows both the CLEM driver and the WinDriver. Check your machine following their instructions to see if you have both listed under the Jungo driver. If not, go to http://www.jungo.com/st/windriver_usb_pci_driver_development_software.html and select the link under "Available WinDriver Toolkits" for your operating systems (I selected WinDriver USB for Windows). It asks a bunch of questions which I didn't know the answer to so I selected "other" on almost everything then entered "NA"or "?" for the other description. Select Download now and it will need to restart your computer. Once done, I looked at the device manager again and now WinDriver is listed under Jungo and CLEM and the software opens, no problems.
This will at least temporarily solve the issue, however, it's a free trial which means the download will expire at some point. Good news is, the windriver is on the futura disk, I just don't know why it's not installing or staying on the machine. I am sending all of this to Singer to figure out what they're missing in the installation files and hopefully get a fix permanently.
SOURCE: Singer CE0100 Futura connection error....
newtosinger, you got a very strange answer. Updates with 64bit Vista/XP and Windows 7 platforms support will be released for all Futura models, just due to higher demand updates for newer machine models are released first. So far updates exist for models ce150/250/350 and ses1000/2000. In a few days will be released an update for ce100/200 that use software 2.5.0.0-2.5.0.2. After that will be released an update for older software versions Futura 1.0.0.x (ce100) and 2.0.0.x (ce200/200E)
SOURCE: I keep get a connection error. Ck that USB cable
Make sure you have the USB plugged into the back USB ports on a desktop computer and try each of the different ports on a laptop computer. What Singer doesn't tell you (and probably isn't aware of) is that the back ports provide more voltage than the front ones (and is also true of certain ports on your laptop). The USB cable and your computerized sewing machine require more voltage than the other ports allowed.
Give this a try-it should do the trick.
SOURCE: I keep getting a connection Error Message. Please
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. If you're using a laptop, keep trying different USB ports until you find one that works. Good luck!
First, there's a Windows 7 update
available at www.Futura-support.com. Click on the lefthand side, then
on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY.
First, be sure the uninstall ALL Futura software you've attempted to
install and reboot your PC.
If for some reason this doesn't
solve you're problem, I've posted a set of instructions at
http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista
that will allow you to run the software under XP on your Windows 7
machine. This is a bit more complicated a solution, but if you follow
the instructions carefully, you should be fine. Try the Futura update
first, though.
I hope this solves that problem.
Next, you say you're "still" having the connection error? Did I answer your problem before? I'm going to give you the answer to the problem I had with this, and if I already gave you this please leave me a comment on this. I check back daily, so I'll see it and we'll try and troubleshoot further from there. First, take care of the software problem. Next, make sure you're plugging the USB cable from the machine into a USB port in the BACK of your computer, not one of the front ports or a port on a USB hub. The cable and machine need more power than most of those ports provide, a technical detail that Singer doesn't realize. Good luck!
