Sometimes you have to call your own # and then the automated voice will tell you that you have not set up a voice mailbox yet. On other phones you will go to your message folder and there is a voice-mail option on it.
Call services
From your phone, you'll be able to access and change the settings of various call
services for your phone.Contact your mobile operator to find out about the availability of call services.
From the Home screen, press MENU and then tap Settings > Call.
Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this
feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings
Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification
If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode
Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings
Edit the call reject message, choose whether to open the message
editor when you reject a call with a message, and choose whether to
allow automatic saving of an unknown contact number when a call
with that number ends.
Cell broadcast
Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings
Configure channels and language for cell broadcast messages.
Call forwarding
Select how you want your phone to handle busy, unanswered, and
unreachable calls. You can also set the call forwarding option for all
incoming calls.
Call barring settings
Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
This can be handled by the DND feature in your admin settings... Do not disturb will transfer your calls direct to voicemail without ringing the handset.
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
if you have voice mail, you can set the number of rings before forwarding to voice mail in the administrative options of the voice mail menu itself. Call your voicemail and listen for administrative options. Follow the prompts.
