SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
SOURCE: POWER ACOUSTIK PADVD-330 DVD Player issues.
if your pioneer radio has the light blue ipbus/changer plug on the back of the radio, you can use this adapter and turn on the <aux> in the menu where you set the clock.
http://cgi.ebay.com/Pioneer-IP-BUS-Aux-In-Input-Adapter-CD-RB10-for-iPod-a3_W0QQitemZ400030920263QQcmdZViewItem
SOURCE: I just bought a car which had this dvd player in
If the clock settinga nd the panel display seems right then we will check on the dvd side. However of the all the lights/display are coming on , not showing any response to the panel then you have a failure of the microprocessor. If not check to clean your head after opening of the set, then insert and watch if the dvd is taken in , played, disc on rotation and read. If not check for transport system, motr failue, link failure, mechanism jammed then if no rotation check for failure of the optical head . replace if you have cleaned the head and checked for any foreign particles. check this out. Good day
SOURCE: My friend said he fried
Unless he connected the black to positive and the red and yellow to negative, it should not have fried his dvd player.
You need to have the remote in
hand. Insert a memory stick or SD
card that has the images you want to use.
When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set
of icons on the bottom. If you do
not see an icon with a hand, press the arrows that are in a circle until you
do. Once you see the hand, press
it one time. It will save the
image onto the internal memory.
You will find the image in the screen tab in settings, under all the
stock images.
