Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation
0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint
adheres to surface of vertical path roller
DescriptionSince a type of paper that can easily
generate lint was used, the paper lint adhered to the surface of the vertical
path roller and decreased the paper feed performance of the roller, causing the
jam code "0105."
Depending on paper sources, the following jams occur.
Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor
PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10
delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry
sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry
sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2
(cassette pedestal) delay jam)
To prevent this, a vertical path roller to
which paper is hart do adhere was used for the following machines (the color of
the roller was changed from black to gray).
- iR2230 120V THF03592 and
later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606
and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW
KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V
KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and
later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW
KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V
KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and
later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596
and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW
KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V
KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and
later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439
and later/230V KFR02186 and later/230V CA SKQ01030 and later
Field RemedyWhen the symptom occurs with the machine
without the foregoing serial numbers, replace the vertical path
roller.
Kindly rate me !!!!!!!!thank mate.
It's utica mbg 150j gas boiler
Hey Bassam, does the burner come on and go out quickly?
I have had the same issue with the Utica boiler code 10 error and the 62. The 10 is a soft shutdown and will retry in 5 minutes then after a few more fails it will go to a code 62 soft shutdown and retry in 30 minutes.
I have searched high and low and seen these boilers have a replacement electric pilot that goes for $125.00 and up.
I fixed mine doing the following.
1 turn off the electricity supply.
2 flame tubes so you can remove the pilot assembly (2 screws)
3 Clean the assembly with non metal abrasive. I used scotch-bright.
4 I also noticed the pilot flame area has a scoop like metal piece that was pressed into the frame on a odd angle. In all the replacement parts this object was not angled but lined up straight with the pilot flame so i made a adjustment with pliers. This bent into position fairly easy. I am wondering if many pilots were pressed in this way at the factory causing this issue.
5 There is a heat shield tube around one of the wires that was not connected at the base where it should have been. A easy fix.
6 Put it all back together and start it up. Worked for me, good luck.
